Becky, I'm sittin' here watching the weather channel, all that stuff is headed our way during the night.
The only leaks I've found around the A/C, believe it or not, were on the four main bolts that hold the inside shroud to the main part of the A/C unit. I think I've a pic or two if you want. These "bolts" are actuall hollow steel tubes that the shroud retainer bolts screw into. Being hollow, they can leak if they are not covered or sealed properly from the top.
