Old 10-01-2005, 10:11 AM   #1
coastal me's Avatar
1999 30' Excella 1000
Northern California , and Oregon
leaks-after sealing
My 1978 Airstream had the roof sealed by an Airstream shop. With the first rain, there are three new leaks. One from the air conditioner, one from the bathroom vent,and a big leak from the upper bathroom cupboard. Has this happened to you after sealing? I'm thinking stress on the roof created new openings.
coastal me is offline   Reply With Quote
Old 10-01-2005, 10:34 AM   #2
Coastal, I've seen seams on the roof open up from my weight on the roof.I've taken that as an indication that the Vulkem was oxidized and due for replacement. I noticed this particularly on the long seam where the awning holder is riveted to the roof. I scraped out the old Vulkem, replaced it with a new bead, and added a layer of aluminum tape for extra sealing.I suspect you are correct.
Nick.
Nick Crowhurst, Excella 25 1988, Dodge Ram 2500 Cummins Diesel. England in summer, USA in winter.
"The price of freedom is eternal maintenance."
nickcrowhurst is offline   Reply With Quote
Old 10-01-2005, 01:29 PM   #3
coastal me.
Did you have the sewer vent pipe cover gaskets replaced?
They must be replaced every 5 to 6 years or so.
If not, strange leaks appear, such as you describe.
Sealing around the A/C Chuck Leaks - Weatherstrips, Gaskets, Caulks & Sealants 1 11-05-2002 04:29 PM
finding/fixing leaks Chuck Leaks - Weatherstrips, Gaskets, Caulks & Sealants 14 10-16-2002 08:32 PM
Water leaks Craig Fresh Water Systems 3 08-08-2002 01:44 PM
Leaks RyeDuck Leaks - Weatherstrips, Gaskets, Caulks & Sealants 11 07-02-2002 09:10 AM
Finding water leaks FrankR Plumbing - Systems & Fixtures 0 06-27-2002 08:36 AM
