Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Leaks - Weatherstrips, Gaskets, Caulks & Sealants
Old 12-09-2003, 08:55 PM   #1
Bob Ward
Profile:
Leaks
I'm working on restoring a 1966 Safari. Lots of fun so far. I need help finding leaks. There is a leak on the floor on both side of the door. Also there is a wet floor in the front corner on the curb side of the unit. The soft spot by the door seems to be common. Anyone knoe the reason for the leaks in this area?
Thanks Bob
Bob Ward is offline   Reply With Quote
Old 12-09-2003, 09:02 PM   #2
wahoonc
Rivet Monster
wahoonc's Avatar
Profile:  1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 35
Bob,
My unit is a lot newer than yours but I will give you a couple of places to start, look for missing rivets, missing caulk around the top of the windows, with an AS the water gets in and follows the shell down to the floor. I have one persistent leak that I may have to pull an interior panel to find. What you can do is pull the panels loose at the bottom and have somone start spraying water at the bottom of the unit on the outside and work their way up until the leak starts to show then you will have an idea of where to look. Just a few ideas to get you started!
Aaron
Old 12-09-2003, 09:05 PM   #3
thenewkid64
Just a member
thenewkid64's Avatar
Profile:  Tampa Bay , Florida
Images: 21
Bob,
In the mid 60's there was no frame over the skin surrounding the door. It is a nice smooth look, but the door seal is the ONLY thing that is going to stop water from getting in. Newer models have a rain gutter on top, as well as a frame to help to divert the water. New seals should take care of the issue. If the floor is not too far gone some rot doctor shoudl fix it and save you from having to do a ton of tear out.
I would check the vulcem over both of the curb side windows. The soft spot further forward may be from the door leak as well. If the vulcem is cracked or gone I would start there to fix this one. Also check the awning rail or any awning mount points high on the trailer. If silicone was used it has failed and will need to be replaced with vulcem. Chasing leaks can be a challenege, but it is satifying when you get one fixed.
Brett G
WBCCI #5501 AIR # 49
"Stop worrying about the potholes in the road and celebrate the journey." -- Fitzhugh Mullan
Wise men talk because they have someting to say; fools, because they have to say something. -- Plato
In politics, absurdity is not a handicap— Napoleon
Old 12-10-2003, 06:13 PM   #4
Bob Ward
Profile:
Thanks for the help. I already have cut out a large section of flooring and when it rained last night I could see that the leaks are comming fron betwwn the skins not through the door weatherstripping. I'm going to look hard at the seams above the rain gutter above the door, and the roof vents. Which brings me to another question. How does one work on the top of an Airstream without denting the roof?
Thanks again,
Old 12-10-2003, 06:23 PM   #5
Pahaska
Pahaska's Avatar
Profile:  2005 28' Classic
Austin (Hays County) , Texas
Images: 12
Thanks again,
The roof will support you quite handily. Wear soft shoes and stay on the rivet lines on the linear portion of the roof. Stay off the end caps ... they dent easily and are sure to result in a fall.
Resting a padded ladder on the awning is a good way to get up there.
John W. Irwin
2005 Classic 28 "Sabre-Dog III"
2004 Silverado 2500HD Duramax/Allison
WBCCI Region 9 Webmaster, #9632
Cooking Forum - Sailing Forum - Early Retirement - Airstream Trailer - Aquarium Forum - Royal Forum - Book Forum - Yoga Forum - Volkswagen Touareg Forum - Jeep Wrangler Forum - Whitewater Kayaking & Rafting Forum - Fiberglass RV Forum - U2 Forum
