Old 03-03-2008, 12:45 PM   #1
Kiah
1970 27' Overlander
North Vancouver and Anarchist Mountain , British Columbia
leaks!
I just got my 70 overlander back and there seems to be some leaks.
The first one is coming from the antenna crank, we removed the antenna so we don't need the crank, anyone know how to seal this? We also have water dripping from the aircon unit, I turned it on yesterday to test it, but only for a few minutes, I wouldn't think it would be condensation, we are havibg heavy rains today so good day to test for leaks.
Any suggestions??
Thanks!!
ID:	55460   Click image for larger version
Name:	leak in aircon unit1.jpg
Name:	leak in aircon unit2.jpg
Kiah is offline   Reply With Quote
Old 03-03-2008, 01:16 PM   #2
Any suggestions??
Thanks!!
Remove all the TV antenna, plate the roof and seal it with Vulkem.
Put a small picture over the inside hole.
Your AC may have a plugged drain line.
Old 03-03-2008, 02:09 PM   #3
Fyrzowt's Avatar
2000 25' Safari
West of Fort Worth , Texas
Images: 8
In addition to the above...
Remove the A/C filters on the inside of the trailer. Check to make sure the hold-down bolts are snug. There should be 3 or 4 bolts.
Fyrzowt is offline   Reply With Quote
Old 03-03-2008, 02:19 PM   #4
balrgn's Avatar
1974 27' Overlander
1954 26' Romany Cruiser
1960 26' Overlander
Rockingham County , New Hampshire
Images: 74
Send a message via AIM to balrgn Send a message via Yahoo to balrgn
Check what I do, never use the old antenna anyway
Leak
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
'54 Cruiser (Bogart)
'60 Overlander (Hoagy)
WBCCI 1754 - AIR # 6281
www.balrgn.com
balrgn is offline   Reply With Quote
Leaks Sundance Sinks, Showers & Toilets 4 07-03-2007 02:47 AM
Leaks (Again?) Jim & Susan Leaks - Weatherstrips, Gaskets, Caulks & Sealants 3 04-27-2005 07:48 PM
Leaks! 1956Safari Leaks - Weatherstrips, Gaskets, Caulks & Sealants 24 03-31-2005 07:39 PM
Leaks Bob Ward Leaks - Weatherstrips, Gaskets, Caulks & Sealants 4 12-10-2003 06:23 PM
Help with Leaks danesh Leaks - Weatherstrips, Gaskets, Caulks & Sealants 10 11-18-2003 09:58 AM
