Old 11-27-2009, 04:07 PM   #1
1968 26' Overlander
Sarasota , Florida
Leaking windows! 1968 Overlander
How can you detect where a window is leaking? We have put new seals on all the windows, cleaned all the old sealants off and they still leak. Need help.
birdie24 is offline   Reply With Quote
Old 11-27-2009, 04:29 PM   #2
silverleeper's Avatar
1967 22' Safari
1960 Caravel
Edmonds , Washington
Images: 8
It's possible that the leak is coming from the seam around or above the window. Water will travel.
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
silverleeper is offline   Reply With Quote
Old 11-27-2009, 04:30 PM   #3
1964 22' Safari
1962 28' Ambassador
enosburg , Vermont
Something to consider. I had a window leak, was sure it was around the upper window frame, could'nt find or stop it. When I removed the inside skins I found it. A seam leak well above the window running down the inside of the outer skin and coming in through a upper corner in the window frame.
putback is offline   Reply With Quote
Old 11-27-2009, 05:25 PM   #4
66-67 and 68 window hinges can leak.
Theat can be corrected by cleaning the exposed part of the hinges where the movement takes place, and injecting silicone sealer.
The window must then be opened and then closed every 10 minutes or so, until the excess silicone is force out.
That opening and closing process should be repeated until the silicone cures out.
That silicone process fills the gap between the 2 hinge halfs, which stops the water leak.
Old 12-08-2009, 07:18 AM   #5
1968 26' Overlander
Sarasota , Florida
Thank you for the information. I really don't see a hinge? The windows seem to be leaking only in the very corners of every window which drips onto the floor. Would eyebrows help?
Old 12-08-2009, 07:21 AM   #6
The eyebrows will make the trailer look tacky.
The hinge is at the very top of the glass, from one side of the glass, to the other side, and must be there or the window would not open.
Old 12-08-2009, 07:41 AM   #7
1967 22' Safari
1960 Caravel
Images: 8
Here is a picture of the hinge. On the second page(87)To install new glass #7 is a little like what Andy is talking about in post #4. Click on pics for larger image. Hope this helps.
Name:	Airstream manual 86.jpg
ID:	92259   Click image for larger version
Name:	Airstream manual 87.jpg
Lee
1973 F-250 4X4 390
AIR 6030
WBCCI 4258
TCT
Old 12-08-2009, 09:00 AM   #8
1968 26' Overlander
Sarasota , Florida
Thank you so much, now I understand! Will try that this weekend..
Birdie
Old 12-08-2009, 09:58 AM   #9
The Flintstones's Avatar
1970 27' Overlander
Houston , Texas
Leaks
We fought mystery leaks for quite a while, we then cleaned and sealed all seams with parbond sealant and it did the trick. Parbond will also flow inside the seam to create a good seal. Good luck I know how frustrating it can be.
____________
1970 Overlander
The Flintstones is offline   Reply With Quote
Old 12-08-2009, 11:38 AM   #10
Silverhobby's Avatar
1967 26' Overlander
1968 30' Sovereign
Mosheim , Tennessee
Speaking of the 1966-67-68 Windows
Parbond does not remain flexible enough to use for sealing the windows. (glass to glass bar) Use good RTV silicone. This is the ONLY place you should use silicone on an Airstream trailer.
//------AIR # 7303------\\
WBCCI 17109
visit my restoration blog at:
Old 12-08-2009, 12:59 PM   #11
Shacksman's Avatar
1960 28' Ambassador
1998 25' Safari
Avonton , Ontario
To find where the leak is, have someone outside with a hose and move from the bottom up slowly till you see water inside. Just use a flow not a wide spray. Mt 67 had water coming past the glass even with new seals. My simple fix is to leave the window just slightly open and the water passes right through.
Doug & Terry
VAC - TAC ON-1
60 Ambassador Int.
98 Safari
1950 Spartan
1966 Globetrotter
Shacksman is offline   Reply With Quote
leaking windows zipman Windows & Screens 9 05-28-2009 04:43 AM
1968 Airstream Overlander losmarios Member Introductions 1 08-02-2008 07:46 AM
leaking windows 1996 Excella widebody srfrgrrl 1994 - 1996 Excella 0 10-20-2007 10:26 AM
Leaking '68 windows U.PenAir Windows & Screens 6 09-25-2007 10:11 AM
leaking and broken windows moogie32 Windows & Screens 51 01-25-2005 08:39 PM
