Old 03-27-2010, 08:17 AM   #1
Aviator's Avatar
1997 34' Limited
1970 27' Overlander
South of Atlanta , Georgia
Leaking water weight
I started thinking last night (yes, my wife was surprised) about all of the posts regarding leaking vent stacks. If your vent has been leaking for some time, the insulation both around the vent and further down into the walls is most likely wet. This could be a lot of extra weight to be hauling around with your trailer.
Does anyone have any idea of how much it could be. With our 34' Excella, using a weight of 8.35lbs (3.79 Kilos) per US gallon it adds up fast!
Craig and Carol
1997 34' Excella 1000
1970 27' Overlander, International
2009 Ford F150 5.4L
ProPride hitch with 1400# bars
AIR 41028
TAC GA-8
WBCCI 10199
Past President Southeastern Camping Unit (12)
Aviator is offline   Reply With Quote
Old 03-27-2010, 08:29 AM   #2
My guess would be that if the vent leak has been rectified, after a few warm days, that water would have dried up and drained out the bottom. there are enough ways for water to leave from the walls, it should be sealed in there. Though some of the ways out will probably include inside the AS unfortunately.
The other thing is what shape the insulation is in if it was leaking for some time.
Old 03-27-2010, 08:50 AM   #3
Airstreamer67's Avatar
The last thing to worry about is the weight. It is a featherweight burden compared with all the things water will do to your rig.
Airstreamer67 is offline   Reply With Quote
Old 03-27-2010, 09:17 AM   #4
fmrcaptevil's Avatar
Weldon Spring , Missouri
Good point, Aviator. Add to that the weight of water that accumulates in the belly pan, (produced by condensation inside the walls).
fmrcaptevil is offline   Reply With Quote
Old 03-27-2010, 09:54 AM   #5
The underbelly water or moisture evaporates everyday, as long as the temperature is above freezing.
Old 03-27-2010, 01:30 PM   #6
Aviator's Avatar
1997 34' Limited
1970 27' Overlander
As a newbie, I didn't realize it could drain into the belly and out from between the walls. Since the factory insulation is fiberglass, it won't absorb water (though it can retain it for some time). I had visions of my 9800# trailer weighed down with a hidden 1000# of water. It sounds from the above responses that shouldn't be the case.
Craig and Carol
2009 Ford F150 5.4L
AIR 41028
TAC GA-8
WBCCI 10199
Old 03-28-2010, 06:38 AM   #7
maybe in California
Old 03-28-2010, 09:44 AM   #8
maybe in California
Everything in California, "is a maybe".
Except our 2 weather seasons, "BAD" and then "WORSE".
Leaking fresh water tank turbo8 Fresh Water Systems 5 08-19-2007 12:44 AM
Water Heater leaking jaiman Water Heaters, Filters & Pumps 2 07-31-2004 04:44 PM
water drain valve leaking - help! wayner1239 Fresh Water Systems 14 02-01-2004 04:10 PM
water drain valve leaking - help! wayner1239 Waste Systems, Tanks & Totes 0 01-31-2004 10:03 AM
Water Heater Leaking Outside overlander76 Water Heaters, Filters & Pumps 8 11-02-2003 03:11 PM
