Old 06-20-2010, 02:00 PM   #1
1988 34' Limited
Sun City, , Arizona
leaking Airstream
We have a leak in our Airstream that appears to be from the air conditioner but are not sure. It doesn't leak when the air conditioner is running. It leaks during the rainy season here in Washington. Water is found under the refrigerator and along the street wall into the living area. We have checked everything but removed the air conditioner. Does anyone have ideas on what else it could be?
kciok is offline   Reply With Quote
Old 06-20-2010, 02:07 PM   #2
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
Leaks can be insidious
Originally Posted by kciok View Post
... Water is found under the refrigerator and along the street wall into the living area...
Welcome to the forum, kciok.
It could be an air conditioner leak, but that is not my first thought.
Your refrigerator has its own rooftop vent for air circulation. I recommend you inspect it first.
Tom
Old 06-20-2010, 02:35 PM   #3
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
When was the last time you renewed the vent stack gaskets? Do you have an awning anywhere near the area? One of my most persistent leaks was a hole under the awning rail that had not been properly sealed, did not find it until I took the awning and rail off.
Leaks in Airstreams in particular can show up a long ways away from where they actually started. There are many different pieces of framing that they can run along before showing up inside.
Aaron
WBCCI #XXXX AIR #2495
1987 airstream excella (leaking in bathroom) browniiis88 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 13 02-01-2010 11:11 PM
09 Airstream leaking goosecrew Off Topic Forum 2 12-12-2009 10:12 PM
'82 Airstream MH Transmission Leaking Greg Stinnett Mechanics Corner - Engines, Transmission & More... 8 10-08-2008 04:32 AM
Leaking '68 windows U.PenAir Windows & Screens 6 09-25-2007 10:11 AM
A/C leaking atvmcg Furnaces, Heaters, Fireplaces & Air Conditioning 13 07-18-2005 03:23 PM
