Old 11-13-2009, 02:28 PM   #1
deauxrite's Avatar
2007 27' Safari FB SE
Full Timers just passing through , Arizona for a couple of weeks and then on to Utah!
Leak tested under pressure!
The trip to the St. Louis area was well worth the effort. As the photos show, soldiermedic found quite a few small leaks in our Safari. Today I got out and worked on all of the issues. I used caulk on some and Cpt. Tolleys on others. It is supposed to rain this week and I am confident that we have resolved all of the leaks.
I spoke to the dealer where I bought the unit about the air bubbles around the air conditioner. He says that the way that the air conditioner is designed, that under pressure, you will always have air passing through. If anyone has different information, pass it my way and we can get the discussion going.
Thanks to soldiermedic for the good work. Fast, professional and very reasonable.
His web site is ifindrvleaks.com
ID:	90868   Click image for larger version
ID:	90870   Click image for larger version
Living life on the Road
deauxrite is offline   Reply With Quote
Old 11-13-2009, 05:54 PM   #2
1962 28' Ambassador
1962 30' Sovereign
Webster Groves , Missouri
Like your cajun spelling of do-right!
Xbob2 is offline   Reply With Quote
Old 11-13-2009, 09:03 PM   #3
deauxrite's Avatar
I enjoyed meeting you xbob2. I hope that we cross paths again.
Old 11-18-2009, 08:35 AM   #4
soldiermedic's Avatar
Florissant , USA
Hey Chief I just saw this thread. Glad we were able to find your issues. Bummer about the AC unit, but what about the water that you were getting? The dealer comment on that at all?
Steve
Streaming Soldiers Blog
soldiermedic is offline   Reply With Quote
Old 11-18-2009, 08:47 AM   #5
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
I'm not so sure. I saw this when you first posted and have been sitting on my hands for a while. There is no path from the inside to the outside associated with the AC except for the drain. It that's the outlet for the drain in the photo and there is no connection to any kind of drain tube, OK.
I'm not sure what kind of AC you have, but that looks like a strange place for the drain.
Glad the rest went well. Steve and family are friends. Best to all.
Vaughan
Old 11-18-2009, 12:04 PM   #6
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Common Sense - If it looks and smells like B.S. ....
Air pressure is a TWO way thing. If the inside air pressure can create that huge bubble on the outside - there is some kind of path for it to do so.
If you watched the weather channel last week, you saw Virginia Beach get hit by a Nor'easter - almost as bad as Hurricane Isabel in 2003. I'll bet I had more OUTSIDE pressure coming in due to 50 mph wind gusts than any test equipment would normally produce.
I deduce that if that much air can penetrate out... rain could penetrate in under high wind conditions.
just my 2 cents
Paula
Old 11-18-2009, 12:34 PM   #7
1983 34' Excella
1967 24' Tradewind
Images: 32
just my 2 cents
Paula
No argument. Not to mention the winds encountered when towing.
The thing with the test equipment is that it is much easier to find a bubble on the outside than it is to track down a leak from the inside. Water that comes in may run down the inner skin for some distance before entering the cabin.
Anything that helps locate problems is a plus in my opinion. I don't think anyone is claiming that this is the ultimate answer, rather another tool. Like all tools, a lot depends on how it is used.
Vaughan
Old 11-18-2009, 01:16 PM   #8
fmrcaptevil's Avatar
Weldon Spring , Missouri
there is an "exterior" drain in that area for the water produced by your heat pump's defrost cycle
fmrcaptevil is offline   Reply With Quote
Old 11-18-2009, 01:28 PM   #9
Alumatube's Avatar
1984 31' Airstream310
New Holland , Ohio
just my 2 cents
Paula
I'm not sure I understand this, Paula -- I thought that is what the pressure testing was all about, to find those paths where rain and other moisture can penetrate and allow you to seal them so it can't. We had a pressure test done by Airstream of Arkansas and they found a good many leaks and sealed them for us. After that, several water-related issues we had been having were gone and we were thrilled! Then, a year or so later, we had soldiermedic test our 310 again to check the seams and to pinpoint where our window seals were leaking. He found several non-window issues that had been baffling us and we took lots of pictures to show which windows were the worst for us to re-seal first. VERY helpful.
To me, this is a great test to show where those "paths" are, regardless of what mechanism could possibly drive water in through them. It was VERY helpful and diagnostic and allowed us to fix some things that had been bothering us for a long time. It's like putting water inside a boat before you launch it to see if it leaks through the hull--the water pressure in that case would be the air pressure here.
Susan
"Despite the cost of living, have you noticed how popular it remains?"
1984 310 Limited Motor Home "The Rockin' A"
Alumatube is offline   Reply With Quote
Old 11-18-2009, 01:33 PM   #10
1962 28' Ambassador
1962 30' Sovereign
just my 2 cents
Paula
From your title you seem to infer that leak testing is bogus ... is this true?
Old 11-18-2009, 02:21 PM   #11
HankandLois's Avatar
2007 27' International CCD FB
Everett , Washington
We've had a few leaks in our unit... known leaks... and the leak testing confirmed it, plus found a few more...
Since then, those leaks have been repaired. Since our unit travels a lot and gets lots of use, so we plan to leak test ours annually. It's good at pinpointing the areas that tend to flex (for lack of better phrase) and keep water damage at bay.
I wrote a post about our experience on my blog. We are totally satisfied with the experience.
/Lois
Air # 20467
WBCCI #4018
Just call us Jean & Bill :-)
HankandLois is offline   Reply With Quote
Old 11-18-2009, 02:30 PM   #12
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
That bubble is front corner of the AC unit. I would have some concern regarding what component is allowing the air to escape. If it is the seal between the pan and the ceiling, it's going to let water in. I've really not examined this area closely. On a typical flat topped or slightly crowned trailer, there is a gasket that forms a seal between the exterior hole in the trailer roof and the air conditioner itself. I'm not clear in an Airstream situation whether the pan and the roof has its own gasket and then another one between the AC unit and the pan. In your situation that area which is leaking is important since from the location that I see in your picture, I'd have the uneasy feeling that towing in the rain might have a high likelihood of allowing water to get in.
I just don't see how a dealer can make a blanket comment like they did, unless they know that based on the picture, a bubble there is not a leak indicator to be concerned about.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 11-18-2009, 02:47 PM   #13
1983 34' Excella
1967 24' Tradewind
Images: 32
Jack
That was my thinking Jack. I just looks like a strange place.
Vaughan
Old 11-18-2009, 03:05 PM   #14
Westfalia's Avatar
2008 27' International CCD FB
Boerne, TX / , Evergreen, CO
Images: 35
Send a message via AIM to Westfalia Send a message via Skype™ to Westfalia
Or they just don't want to fix it.
Chris and Christina- Boerne, TX / Evergreen, CO - TAC TX-7
2008 27'FB Int'l Signature CCD
Westfalia is offline   Reply With Quote
Home Made Pressure Leak Test BossCamper Leaks - Weatherstrips, Gaskets, Caulks & Sealants 10 10-07-2011 08:19 PM
water pressure regulator leak. kss Plumbing - Systems & Fixtures 1 01-15-2009 09:25 PM
Tested the Magic Chef/Thanksgiving Dishes Lothlorian Stoves, Ovens & Microwaves 4 11-27-2008 02:34 PM
Intellipower in and tested… Buttercup Electrical - Systems, Generators, Batteries & Solar 16 06-27-2005 03:35 PM
Pressure Method of Leak Detection mcneon Leaks - Weatherstrips, Gaskets, Caulks & Sealants 14 10-18-2004 07:12 AM
