Old 05-03-2017, 12:19 PM   #1
Hail on wheels
GeGe's Avatar
1992 25' Excella
Little Elm , Texas
Leak near water connection
1992 Excella - we found a bad leak this year when we attached the water hose to the water connection. The right rear compartment was wet and then it started leaking in several areas at the top of the rear compartment. This only happens when the water is connected and on.
Does anyone know what the issue is and how to fix it.
Gege
GeGe is offline   Reply With Quote
Old 05-03-2017, 01:15 PM   #2
CRH
1995 25' Excella
xxxxx , xxxxxx
Sounds like a ruptured pipe. No way to tell without looking into hidden areas for the leak.
CRH is offline   Reply With Quote
Old 05-18-2017, 08:43 PM   #3
Hail on wheels
GeGe's Avatar
1992 25' Excella
Little Elm , Texas
Smile found issue with water leak
we replaced the city water pressure intake and no more leak. Thanks for your help!.
Gege
Leak near fresh water tank drain F1reh0lder Fresh Water Systems 12 03-12-2015 09:07 PM
Leak from hose near City water hookup U3270 Waste Systems, Tanks & Totes 5 11-16-2013 02:23 PM
Leak with City Water Connection Dreamnair Fresh Water Systems 1 08-23-2009 07:12 PM
Leak Under City Water Connection JDL Fresh Water Systems 8 08-14-2006 01:16 PM
Can't find water leak - near fresh water tank. Loren Fresh Water Systems 16 01-01-2006 05:40 PM
