Old 03-30-2013, 11:34 AM   #1
adwriter73's Avatar
1978 31' Sovereign
Dallas , Texas
Leak near tail light, but it's not the tail light
I have been tracking this leak for months. I used Vulkem and Parbond in every location where I thought this leak could be starting, and it's still showing up. I attached a photo and indicated in red the areas within the wall that I can feel wet insulation. What makes me think it's not the tail light is that I can feel moisture above the tail light assembly. Where else should I check?
adwriter73 is offline   Reply With Quote
Old 03-30-2013, 12:28 PM   #2
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
How far up above the tail light are you feeling wetness? It might be wicking up from the tail light. Or might it be leaking at the window and wicking over and down. Or maybe from the banding? Puzzlement...
Kay
Old 03-30-2013, 02:45 PM   #3
1977 Argosy 24
Milltown , Wisconsin
Do you have clearance lights up high on the corners?
ventport is offline   Reply With Quote
Old 03-30-2013, 10:00 PM   #4
adwriter73's Avatar
1978 31' Sovereign
Dallas , Texas
There's a hole (for wire) at the top of the tailight assembly in the wall. I can get a finger in there an feel moisture. So, it has to be the window or the clearance lights. My guess is the window, but I can't tell how. Based on everything I've checked, there's no areas for water to get in the wall.
Old 03-30-2013, 10:02 PM   #5
adwriter73's Avatar
1978 31' Sovereign
Dallas , Texas
Kay
I was wondering about the banding, but how would that leak? I mean, it's just decorate trim that's riveted on, right?
Old 03-30-2013, 10:42 PM   #6
Protohyp's Avatar
1977 31' Excella 500
Los angeles , California
Send a message via AIM to Protohyp
I posted this a while back. maybe it helps you locate
http://www.airforums.com/forums/f142...ts-100647.html
Protohyp is offline   Reply With Quote
Old 03-31-2013, 10:44 AM   #7
Minno's Avatar
1972 31' Sovereign
Our banding was only riveted on with pop rivets, so if they're not sealed at the back, they could potentially leak. We also had a piece of banding fall off while she was still sitting in the yard being worked on. That prompted us to decide to completely re-rivet all the banding before taking her on the road. We used closed end pop rivets to do this, drilling out a few and replacing before going on to the next set. Took me most of an afternoon, but it's now all solid and sealed.
Water might also potentially travel from other areas, such as the curved area above your window. Might be a long shot, but people have had water show up on the floor that came from the roof and down a wall. Water will always seek the path of least resistence and if there's a small leak up there, it could run down the outside wall till it hits insulation to soak into. Stranger things have happened!
Kay
Old 03-31-2013, 11:34 AM   #8
Maniacal Engineer
barts's Avatar
Menlo Park , California
In our 1971, we had problems with leaks around the taillight housing. I'd definitely make sure that the housing is thoroughly caulked. I used Alcoa aluminum gutter seal since it's a very visible (near eye height) location and that stuff leaves a nice bead if carefully done.
- Bart
Bart Smaalders
Menlo Park, CA
http://tinpickle.blogspot.com
http://smaalders.net/barts
barts is offline   Reply With Quote
