Old 05-01-2009, 09:45 AM   #1
Alsupp's Avatar
1984 31' Sovereign
Andover , Kansas
Leak Near Battery Box - 83 Sovereign
Well, I have been battling a leak in my new to us '83 Sovereign 31' . It is under and near the battery box at the front of the trailer. I have replaced the window seal above and re-sealed all the obvious seam leaks at the entire front of the trailer with Sikaflex 1A, but there is still some dampness.
We are having lots of rain here in Kansas right now, so I have not yet had a chance to try the 'ol garden hose trick. Has anybody else fought a similar battle and have a tip on where to look?
The pressure testing concept sounds neat - I may just have to rig up something like that!
Alsupp is offline   Reply With Quote
Old 05-01-2009, 12:34 PM   #2
WBCCI 11067 WDCU
ckeysor's Avatar
1986 25' Sovereign
Atlanta , Georgia
Images: 30
Does it leak just sitting there or when travelling? I had a panel underneath leaking and it was wicking up through the insulation to the floor board. I would also consider the vent on the roof.
Chris Keysor
WBCCI 11067
1986 Sovereign 25' CB
2007 Chevy Silverado 1500
2007 Toyota Land Cruiser
ckeysor is offline   Reply With Quote
Old 05-05-2009, 10:29 AM   #3
Alsupp's Avatar
1984 31' Sovereign
Andover , Kansas
Thanks for the response - I checked up top and everything appears OK. I did, however, find the corners of the square window frame were most likely the cause of the leak. Having sealed them up, I believe the worst is over. I am tempted to simply seal that front window permanently shut, but will refrain for now!
Old 05-05-2009, 10:38 AM   #4
blickcd's Avatar
Milford , Ohio
I had a leak above both battery boxes on my '79. I know your leak looks like it is below the box, but just in case it is above and running down the side where you can't see, let me tell you how I fixed mine.
My leak turned out to be the seams, which looked tight outside but water seeped in and eventually oozed out of a pinhole leak in the sealant on the inside. I discovered this while I had the inner wall skin off and insualtion removed for another project. The fix was to scrape out some old sealant around the leaks and apply some fresh vulkum, and wait for a few rains to make sure the job was really done.
I know you have sealed the outside of the seam, but you just never know. I might also suggest you look at the fasteners along the bottom flange of the battery box, and even remove the battery so you can inspect the inside for cracks.
Christopher
blickcd is offline   Reply With Quote
Old 05-05-2009, 11:50 AM   #5
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Seams, Lights, Window(s), Rock protector, level (if mounted) and anything else above the area. You have stringers that run the length of the trailer that could be channeling water towards the front of the trailer. For fun, try tilting the trailer so the nose is higher and see if the leak goes away. I have also found there is seldom a single source for a bad leak, it is usually a confluence of multiple smaller leaks.
Aaron
WBCCI #XXXX AIR #2495
New Battery Box 68 Overlander Commercial Listings 10 09-30-2010 06:25 AM
Battery Box ? aviontt Batteries, Univolts, Converters & Inverters 1 04-17-2005 07:31 PM
locks for battery box and propane box Chilao Doors & Locks 11 11-02-2004 06:56 PM
Battery Box aztlanco Batteries, Univolts, Converters & Inverters 5 08-17-2004 05:56 PM
