Old 10-19-2010, 07:02 AM   #1
1999 25' Safari
Hickory , North Carolina
Question leak in curb side rear storage compartment,1999safari 25 ft.
I have a leak in the rear curbside storage comp. I have had the trailer to an Airstream dealer several times and the have done some caulking and sealing around the rear window and side window and the comp door. The leak is still not fixed. The dealer tells me they have done all they can do. I would be interested to find out if other owners have had similar problems and a fix for this persistent leak. Thanks, Sam.
samf3355 is offline   Reply With Quote
Old 10-19-2010, 07:32 AM   #2
Silverhobby's Avatar
1967 26' Overlander
1968 30' Sovereign
Mosheim , Tennessee
I sent you a PM.
//------AIR # 7303------\\
WBCCI 17109
visit my restoration blog at:
Old 10-19-2010, 09:21 AM   #3
If there is a sewer vent pipe in that area, then check the gasket on the roof, as they only last 2 to 3 years.
Old 10-19-2010, 01:41 PM   #4
1999 25' Safari
andy,thanks for your interest,there is no vent pipe in the area of the leak,in fact there in nothing on the roof on that side of the camper exept the back end of the awning,thanks sam
Old 10-19-2010, 01:51 PM   #5
I would then suggest that you carefully check the awning brackets and their rivets or screws for a proper seal.
You can also spray that immediate area with water, and see what happens.
Leak in both rear compartment?!? coffeydelsol Leaks - Weatherstrips, Gaskets, Caulks & Sealants 3 05-31-2009 12:07 PM
Rear Storage Compartment Does Not Lock? TheThreeSeas 2007 Safari SE 4 03-27-2007 04:05 AM
Rear Storage Compartment collects water..... MontanaArgy All Argosy Trailers 3 11-03-2005 11:28 AM
Water Leak - Curb Side ViewRVs Airstream Motorhome Forums 5 09-15-2003 03:01 PM
