Old 04-15-2008, 10:54 AM   #1
1973 Argosy 28
etters , Pennsylvania
leak in ceiling
Last week, while at our camper our son informed us that the corner of his cover was wet. The carpet beside his bed was damp also. I felt around the A.C. and it felt dry. While it was raining outside I looked again and noticed there was some water seeping from the seam in the cieling, about 8 inches from the A.C. Our camper is on a permanant spot and seems to lean alittle to the back. I thought that since the camper leans that way that maybe the seal around the A.C., on the roof, was leaking. My husband glanced at the roof last week and didn't see any cracks in the roof or anything. Going up again this weekend. Any Ideas? If it is the A.C. seals how's the best way to repair? Thanks
The Oats is offline   Reply With Quote
Old 04-15-2008, 11:15 AM   #2
mandolindave's Avatar
Maybe????? it's not a leak ( maybe )!!!!!!!
Sometimes campers that are in tip top shape are a little too air tight. They can actually develop their own weather systems. ( Again, maybe ) Dave
mandolindave is offline   Reply With Quote
Old 04-15-2008, 11:15 AM   #3
Check the "sewer vent pipe cover gaskets."
They are good for 5 to 6 years,. at best.
Old 04-15-2008, 11:42 AM   #4
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
and this is exactly what happened on my trailer. bad sewer vent gasket...water dripping over the end of the bed, probably 8-10 feet away, and the ceiling seam is up higher than the vent! what happens is that the insulation in the ceiling soaks up the water, and it can wick it uphill. it could come out "anywhere".
I suspected the AC, too, as its the closest thing. But that wasnt' it. Not that this isn't your problem...it could be. different models of AC attach to the trailer differently, so exactly how/what to look for will vary. But as Andy says, that sewer vent is a very likely culprit.
I only got a drip inside when it was really raining hard. big "downpours". In light rain, it wasn't noticeable. I'd have to draw a diagram to explain it, but it makes sense.
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 04-15-2008, 12:32 PM   #5
soldiermedic's Avatar
Florissant , USA
I just replaced my Air Conditioner gasket and found an additional problem while in the process. Both were letting water into the trailer with no impedance.
Since I am not familiar with your AC brand, I cannot tell you for sure how to remove it. I would start by removing the interior ceiling control panel. After this, look for bolts that would be going through to the roof unit, and remove them. Once all the bolts are out, you can get up on the roof and remove the AC unit. Ensure you ONLY step on the ribs (Where all the rivets go across from side to side). Place a piece of cardboard down to move the AC unit to once you remove it.
Remove the gasket from the AC unit, and replace with new...too easy. When replacing the AC unit back on the roof, have someone inside make sure your gasket is seating properly around the 14x14 hole. Once it is back on, time to screw the bolts back into the roof unit. Ensure you don't exceed more than 5 foot pounds of torque on these bolts or the gasket could wind up worse than it began.
Hope it helps.
Steve
Streaming Soldiers Blog
soldiermedic is offline   Reply With Quote
Old 04-15-2008, 01:18 PM   #6
enduroryda's Avatar
1994 21' Sovereign
Down on the corner... , CT
Here's a really good link for repairing your sewer vent...something I should probably get up and do in the near future.
http://www.airforums.com/forums/f163...nts-24437.html
Ann & Eric
WBCCI 6274
TAC CT-4
NEU
enduroryda is offline   Reply With Quote
Ceiling lights niftypkg Lights - Interior & Exterior 4 03-04-2007 05:01 PM
New To You-- Greek To Me- Ceiling Help artisan765 1965-1969 Sovereign 9 07-15-2006 05:29 PM
Ceiling sag.... Terry C. Tullier General Interior Topics 6 08-01-2005 04:02 PM
Ceiling? balrgn General Interior Topics 8 10-22-2004 05:19 PM
possible plumbing leak or water leak jamesl Repairing/Replacing Floor &/or Frame 1 04-06-2003 10:52 AM
