Old 06-29-2009, 07:42 PM   #15
SilverCottage's Avatar
2007 27' Safari FB SE
LONDON , ON
Originally Posted by Shepstream View Post
Seeing as the rain continues and I haven't had the chance to take any action other than to dry out what had gotten wet and place a few towels ahead of where the water ends up: I used the opportunity to document more precisely how the water is coming in. The photos show a drop leaching onto the screen at the top curbside of the front window, just between the rivet and the screw. I cant find any water above the screen bezel inside - nor is there anything obvious outside. The leak does not seem to change if the front window is open or closed. The leak is first visible at this precise location even if trailer has a slightly different roadside/curbside tilt. Based on this information, is there an obvious place to check next? Thanks in advance! -Shep
FWIW our 2007 leaked like crazy in the exact same spots as yours after a year of ownership. We put it away in covered storage last fall with plans to take it to JC this spring to get fixed. Even though we have been in several heavy downpours this spring, not 1 drop has come in despite doing nothing.
I guess it is time to head up on the roof and check everything anyways.
SilverCottage is offline   Reply With Quote
2008 Safari SE 27FB Front Storage Compartment wayner61 2008 Safari SE 10 01-29-2015 10:17 PM
front leak tinsltootsie Leaks - Weatherstrips, Gaskets, Caulks & Sealants 16 12-29-2008 08:42 AM
Leak above front window Greg26 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 8 09-07-2008 10:14 AM
front window leak cadmando Lights - Interior & Exterior 3 10-01-2007 06:44 PM
Front Holding Tank Leak Deejay Fresh Water Systems 0 07-08-2003 08:29 AM
