Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Leaks - Weatherstrips, Gaskets, Caulks & Sealants
Prev Previous Post   Next Post Next
Old 09-04-2009, 06:55 PM   #1
Profile:
Question Leak driving us nutz!!!
I know every one of these situations is different but I'm going to toss this out there anyway just on the off chance somebody has gone through the same thing. Trailer is 1988 29' Excella. There is a leak (I think) somewhere between the streetside window, next to the table, and the front wrap window. We have a section of the floor up because we are replacing it, adding new flooring and installing twin recliners in place of the couch. The leak will show up with even an overnight dew fall. If I put a light mist hose on it from the bottom of window lets say, to bottom edge of underbody wrap, (the dark grey) metal, a leak will develop in a few minutes as a trickle that runs from edge of C-channel into belly pan.
Any ideas? I have caulked every seam I can see from the front all around back halfway to rear of trailer. A couple years ago a (so called) Airstream Expert shop plastered a five inch wide strip of caulking all the way across the top so I doubt anything will leak through that!!
What..........?
Anniedog is offline   Reply With Quote
Leak: Fired Up Hot Water, Now There's A Leak SSChanger Fresh Water Systems 4 07-15-2009 09:46 PM
This leak is driving me nuts Alumi-Naught Leaks - Weatherstrips, Gaskets, Caulks & Sealants 2 06-13-2006 05:13 PM
Which AC while driving? Chaplain Kent General Motorhome Topics 18 07-10-2005 10:18 PM
possible plumbing leak or water leak jamesl Repairing/Replacing Floor &/or Frame 1 04-06-2003 11:52 AM
'99 25' Safari water leak driving me crazy Raptorrider2001 1999 Safari 4 12-06-2002 07:34 PM
