Old 08-29-2013, 04:15 PM   #1
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Leak at rear bumper storage rotted floor inside
I have a leak at the junction of the rear bumper storage cover, exterior skin, and the U channel where the walls studs connect. This allows water into the interior, which has rotted the wood floor. Thought I would post some photos of my repair.
First I removed the vinyl rub rail insert, removed the screws holding the metal rub, drill out the pop rivets holding the rub rail. I cut the caulk joint between the metal rub rail and the exterior aluminum skin. This allowed me to pull the metal rub rail away to expose the leaking joint. You can see in the photo there is absolutely no caulk at the joint where the U joint sets on top of the hatch.
Name:	1 remove rub rail.jpg
After the open joint was exposed I scraped excess caulk with a plastic putty knife, then cleaned the join with alcohol and a tooth brush, then wiped it clean with paper towels. Repeated several times.
Name:	2 cleaned joint.jpg
Then I masked the joint with painter's tape and caulked the joint.
Name:	3 mask open prior to caulk.jpg
Name:	4 caulked joint.jpg
Alan
Old 08-29-2013, 04:26 PM   #2
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Question Leak repair
I reinstalled the rub rail, using stainless steel screws and aluminum pop rivets.
Name:	5 reinstall rubrail.jpg
Name:	6 Reinstalled rub rail.jpg
Then I masked with painter's tape and caulked the joint at the top of the rub rail.
Name:	7 mask top of rubrail.jpg
Name:	8 caulked top of rubrail.jpg
I do not have the adhesive, so I will have to wait until tomorrow to re-install the vinyl rub rail insert.
Can anyone tell me how long I should wait for the caulking to cure before using Acryl-R to seal the caulk joint?
Alan
Old 07-08-2014, 07:27 PM   #3
1975 31' Sovereign
Cedar Bluff , Virginia
I can't answer your question but I appreciate the post. I have the same situation and your quite will be very helpful.
Thanks, Pete
Airlifter is offline   Reply With Quote
Old 07-08-2014, 07:53 PM   #4
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Thanks, Pete
The whole reason for posting was to help others in the same situation.
I'm glad you could use it!
Alan
Old 07-08-2014, 09:32 PM   #5
drew05's Avatar
2011 25' FB Flying Cloud
Peculiar , Missouri
How did you remove the vinyl rub rail insert?
Thanks for posting the pictures.
drew05 is offline   Reply With Quote
Old 07-09-2014, 12:32 AM   #6
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
The vinyl on mine was a dense foam with a silver vinyl coating. It originally had a two side adhesive tape holding it on. Where the aluminum bar terminated near the water heater I worked a flat screw driver under the end of the vinyl. Then lifted the vinyl up and pealed it slowly off using a narrow plastic putty knife working underneath, trying not to pull hard on it. I rolled it on itself all way around the back. Then hung it on the end of the bumper while I worked.
I scrapped the adhesive residue and bits of foam off of the aluminum chanel then cleaned it with alcohol and mineral spirits.
I used an adhesive, windshield adhesive I think, to stick it back on when I was done. I used screws twisted by hand into each side of the vinyl strip, like wedge, which held it place until the adhesive set.
If the vinyl is to far gone and you want to replace it, just rip it off. You can get new vinyl at ODM or Inland RV. It's pricey though!
Alan
Old 07-09-2014, 05:00 AM   #7
Baltimore , Maryland
That bumper hatch has been causing issues since 1963. If Wally were alive he would have corrected it 51 years ago.
Old 07-09-2014, 07:11 AM   #8
1981 31' Excella II
New Market , Alabama
So how did you replace the floor on the inside? That has to be done properly as well. As Frank said above that plate that goes under the floor has been causing problems for a long time.
Perry
Old 07-09-2014, 07:53 AM   #9
1975 31' Sovereign
," Can anyone tell me how long I should wait for the caulking to cure before using Acryl-R to seal the caulk joint?"
What is Acrylic-R? Is it necessary to use it to seal the caulk?
I do not have Tempro635. I will be using a polyurethane from a local home supply store. Is this adequate?
Old 07-09-2014, 01:06 PM   #10
1981 31' Excella II
You don't need to seal the caulk with another caulk. The polyurethane or the Acryl-R but not both.
Perry
Old 07-10-2014, 08:46 PM   #11
1975 31' Sovereign
I started the repair today. I got the rub rail off and removed the caulk at the bottom. I also removed what looks like the remnants of a seal. It was so deteriorated that is not reusable if that is what it is.
I am waiting for a call from Airstream about a part number and any information I can get.
Any thoughts?
BTW I have a 1975 sovereign with the rear bedroom
Old 07-10-2014, 09:59 PM   #12
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Arcryl-R is a sealant used to seal really thin joints where caulk will not get inside the joint, like those where the metal skin segments overlaps.
Acryl-R Seam Sealer 28430w-01 [28430w-01] - $34.95 : Out-of-Doors Mart!, More Airstream Parts on-line than anyone!
The reason I asked about curing time is because I had both types, caulk joints and Acryl-R joints that intersected. I waited a few days then did the Acryl-R. No problems.
Alan
Old 07-10-2014, 10:18 PM   #13
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Perry
I have another thread about the repair. http://www.airforums.com/forums/f36/...xy-108608.html
I caught it before it got to bad. It's been almost a year and I've towed about 1,200 miles. No leaks since the repair, the plywood is solid, and the patch has held up.
Alan
Old 07-11-2014, 07:12 AM   #14
1981 31' Excella II
I don't know why Airstream went to that sticky back trim stuff. I would be tempted to go back to the old insert trim which is much easier to take on and off when you need to do maintenance.
Perry
