Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Leaks - Weatherstrips, Gaskets, Caulks & Sealants
Old 05-26-2007, 02:41 PM   #1
chuman70
Profile:  1974 25' Tradewind
Muscle Shoals , Alabama
Leak around range hood vent '74 Tradewinds
I have a slow leak around my range hood vent on my '74 Tradewinds. Does anybody here know an easy way to stop this?
chuman70 is offline   Reply With Quote
Old 05-26-2007, 03:44 PM   #2
CanoeStream
CanoeStream's Avatar
St. Cloud , Minnesota
Images: 13
Good afternoon! We've got a very slow weekend around here. I would suspect that you have compressed and hardened weather stripping allowing rain to splash and enter at the junction to the body of your Airstream. You'll probably need to scrape this off and apply some new with 3M Weatherstrip Adhesive.
Old 05-26-2007, 03:50 PM   #3
CanoeStream
Images: 13
You'll also want to take a look at http://www.airforums.com/forums/f164...nts-24437.html -- that's a common way for water to get in on trailers this old.
Old 05-29-2007, 01:33 PM   #4
azflycaster
azflycaster's Avatar
Profile:  1975 25' Tradewind
Phoenix , Arizona
Images: 60
I had the same leak on my 75 Trade Wind. I pulled the motor and housing from the outside and sealed under the seam with vulkem. The hardest part for me was getting the cable from the door attaced to the lever on the control panel when I was done.
Richard
Charter Member Four Corners Unit
azflycaster is online now   Reply With Quote
Old 05-29-2007, 03:54 PM   #5
Tom Nugler
Tom Nugler's Avatar
Profile:  1967 20' Globetrotter
McHenry County , Illinois
I just finished refurbishing the stove vent hood on the GT this weekend. I found it interesting that where the vent went through the inner skin was very snug, but, the outer skin had a gap of almost 3/8 of an inch where the cap screen sat under the vent cover. In addition the cover had been cracked where the awning had pushed against it for years.
I figured this was too much for any sealer to fill properly so I cut and fit a thin piece of aluminum sheet from the hardware store to fit tightly around the screen and under the lip of the vent cover.
Probably shoud have taken a few pics to illustrate what I did.
Tom.
Airstream Forums Member # 2806
WBCCI # 6411
Not All Who Wander Are Lost.
Tom Nugler is offline   Reply With Quote
Water Leak jcanavera Leaks - Weatherstrips, Gaskets, Caulks & Sealants 9 06-03-2005 09:28 AM
2003 International AS Pahaska 2003 International 147 05-28-2004 10:48 AM
Loud range hood fan lbrodsky 2001 Safari 5 09-26-2003 07:08 AM
1985 Excella shower vent fan gimmejul Roof Vents, Skylights & Fans 8 05-01-2003 08:56 PM
Rainwater leak James Schmidt Leaks - Weatherstrips, Gaskets, Caulks & Sealants 8 09-11-2002 07:28 AM
