Old 03-29-2010, 03:14 PM   #1
Goffstown , New Hampshire
Leak
I have a new (leftover) 2008 27FB safari that has a leak in the front window area (by the bed). The water is running down the front window screen onto the wood area where the mattress was (removed it when I noticed the leak). Yes, the window is closed and secured... of course it's raining here in NH and will be for a few days.
It's probably coming in over the window area. Anyone else have a similar leak with this model?
I'm bringing it back to the dealer for a couple of clean-up items but would like to stop this leak now before any water damage occurs.
Bobdes is offline   Reply With Quote
Old 03-29-2010, 03:33 PM   #2
soldiermedic's Avatar
Florissant , USA
Have them check not only the window and gaskets, but the roof vent, skylight, and any other item attached to the exterior skin above the area. Also you can seal the marker lights on the cap.
Steve
Streaming Soldiers Blog
soldiermedic is offline   Reply With Quote
Old 04-10-2010, 11:00 AM   #3
Whirlaway's Avatar
2008 27' Classic FB
Anytown , Massachusetts
I have the same problem only the rear middle window.
I just posted this today see Colin Hyde leak tested my AS.
I am going nuts trying to figure out where it is..
Lin.
Life Is Not A Dress Rehersal
It's okay to have too much fun
WBCCI #8701* TAC MA-1 * NEU UNIT
Gracie...A Liver & White GSP
Get busy livin', or get busy dyin'." - The Shawshank Redemption
Whirlaway is offline   Reply With Quote
How To Get to a Leak? NashBuff Fresh Water Systems 5 11-05-2009 02:00 PM
Leak: Fired Up Hot Water, Now There's A Leak SSChanger Fresh Water Systems 4 07-15-2009 08:46 PM
Leak Alaska1966 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 5 09-11-2007 12:07 PM
A new leak wayne.yl Leaks - Weatherstrips, Gaskets, Caulks & Sealants 10 01-14-2005 07:10 AM
possible plumbing leak or water leak jamesl Repairing/Replacing Floor &/or Frame 1 04-06-2003 10:52 AM
