Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Leaks - Weatherstrips, Gaskets, Caulks & Sealants
Old 08-15-2009, 09:11 AM   #1
blickcd's Avatar
Profile:  1979 31' Sovereign
Batavia , Ohio
Late 70's pyramid shaped plumbing vents
My trailer is a 1979 and the plumbing vents on the roof are aluminum, sort of a pyramid shape, with the peak cut off. I've heard of the gasket on the round vents deteriorating and causing major leaks but was wondering if these type need any periodic inspection or have known flaws and if so, known cures. They look okay on the outside and I see no signs of leaks inside, but then again the vent stacks are concelaed.
Christopher
blickcd is offline   Reply With Quote
Old 08-15-2009, 09:22 AM   #2
Janet's Husband's Avatar
Profile:  1977 Argosy Minuet 6.0 Metre
1977 Argosy 24 Rear Door
Eastern , Washington
Christopher
The gaskets do deteriorate after a while and leak. They are available precut or you can make your own. I would just buy them, much easier.
Peace
Gary
Janet's Husband is offline   Reply With Quote
Old 08-15-2009, 10:31 AM   #3
geezernbabe's Avatar
Profile:  1970 31' Sovereign
Shingle Springs , California
When you replace the gasket if they are like mine on our 1970 they will have a small drain hole in the lower part of the vent cap, it seem to get pluged easy. It lets what small amount of rain water that falls in out.
geezernbabe is offline   Reply With Quote
31' AS vs 25' AS Vintage Models, late 70's trogers713 On The Road... 5 04-17-2008 05:33 PM
Somebody with a 31' Late 70's Airstream wacnstac Cabinets, Counter Tops & Furnishings 4 08-21-2006 11:34 AM
How prevalent are leaks in late 70's era airstreams? wacnstac Leaks - Weatherstrips, Gaskets, Caulks & Sealants 14 03-03-2006 07:46 PM
Need advice: Toyota Tacoma 4X4 Ext. Cab for late 70's 25' Tradewind? thierry Tow Vehicles 20 02-08-2005 07:10 PM
Brake/Turn Light Wiring Question (late 70's) DPeakMD Electrical - Systems, Generators, Batteries & Solar 3 07-14-2004 01:46 PM
