Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Leaks - Weatherstrips, Gaskets, Caulks & Sealants
Old 07-07-2007, 08:54 AM   #1
JimGolden
JimGolden's Avatar
Profile:  1977 31' Excella 500
Kool Seal or Vulkem for roof
Hi All,
Got some roof leaks in my new to me Avion (yeah I know....but it is silver and one trailer is never enough ).
I was told by an Avion guru to use only Kool Seal on the roof seams. I read a whole bunch of postings on here about roof sealing. Looks like a lot of guys really like the Kool Seal. Others say Vulkem, but disagree on which vulkem.
What should I use to go over the roof seams?
thanks!
- Jim
JimGolden is offline   Reply With Quote
Old 07-07-2007, 09:02 AM   #2
overlander63
Rivet Masher
overlander63's Avatar
Profile:  1974 31' Sovereign
L.A. , California
Jim, I used (white) Kool-Seal on the roof of our Argosy, it sealed the seams, and helped insulate it a bit. It was noticeably cooler inside after applying it. IIRC, there is white and grey, obviously if you use it, I would go with the grey, and you could probably coat the center panel to help with keeping the trailer cooler like we did with our Argosy. Supposedly, it will allow streaks to run down the side of the trailer, we never saw them, but the trailer was the same color as the streaks would have been.
Old 07-07-2007, 09:09 PM   #3
JimGolden
JimGolden's Avatar
Hi Terry,
I picked up two gallon jugs of Kool Seal at Lowes tonight. Got a jug of the patch, and then a jug of the elastomeric sealer. I did get white. I'm planning to paint the roof white anyway. I thought I remember reading on here last night where one guy used the patch to fill in the dried out stuff and then went over it all with the elastomeric sealer. Sounded good to me
Did you have to etch the aluminum first before putting the Kool Seal on? Or is it good to go right out of the jug? If its good to go, I'll put her on tomorrow.
Thanks!
- Jim
Old 07-07-2007, 09:28 PM   #4
overlander63
Rivet Masher
L.A. , California
Thanks!
Our trailer was painted, but all I did was slop some out of the bucket, and roll it out with a cheap paint roller. I bought a gallon, and had about a quarter of it left over after two coats. It's supposed to last at least 5 years.
Old 07-07-2007, 09:28 PM   #5
wahoonc
Rivet Monster
wahoonc's Avatar
Profile:  1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 35
Hi Terry,
Thanks!
Jim,
I am pretty sure that stuff will stick with no etching. I did some patch repairs on my wife's storage trailer and my storage connex and both of them have aluminum roofs, and neither one leaks anymore. I am planning on using some type of elastomeric coating on my AS roof when it gets to that point. Whether Kool Seal or some other brand has yet TBD.
Aaron
WBCCI #2449 AIR #2495
Old 07-07-2007, 09:37 PM   #6
JimGolden
JimGolden's Avatar
Thanks guys. I may try putting some of that on tomorrow. Supposed to be 95 degrees out tomorrow. Yikes!! May wait until evening
- Jim
Old 07-08-2007, 07:48 AM   #7
overlander63
Rivet Masher
L.A. , California
Do it in the morning, just after the dew dries. Then it will have all day to "cure".
Old 09-04-2008, 04:58 PM   #8
amalgamator
Profile:  1966 24' Tradewind
Valley Village , California
I just stumbled on this thread so I haven't read very much about Kool Seal but, from what was posted here, I'm wondering what you think about painting the inside of the outer aluminum shell.
I'm going to be removing the interior panels for some electrical work and I'm not thrilled about the idea of painting the top of the AS white or grey.
If I painted it on from the inside, do you think it would seal it and help with the insulation?
amalgamator is offline   Reply With Quote
Rubber Door Seal Replacement Road Ruler Doors & Locks 6 01-01-2003 09:01 PM
seal the bottom edge trim pieces? cindy Leaks - Weatherstrips, Gaskets, Caulks & Sealants 8 10-23-2002 10:18 AM
Door Seal Types ??? Road Ruler Doors & Locks 3 09-07-2002 06:53 PM
Vulken and Polish or Polish then Vulkem? rookie Cleaning, Stripping & Polishing 5 07-23-2002 08:15 AM
Removing Vulkem JrnymnJay Leaks - Weatherstrips, Gaskets, Caulks & Sealants 3 05-04-2002 12:49 AM
