Old 09-04-2016, 09:27 PM   #1
1992 29' Excella
seattle , Washington
It rains in seattle finally and we can see leaks
We knew there were leaks because of several areas of floor rot. It rained and we didn't see any water pooling up in the floor rot areas. However, the next day, we proceeded with cutting away sections of rotten sub floor and found pools of water underneath.
Since I can't see any water running along the interior, I'm assuming these leaks are somewhere in the roof? Or perhaps around the window frames on the exterior.
I read about some sort of sealant you are supposed to apply annually. I want to hit every window and every perforation with this stuff. Any recommendations?
My plan is to do the leak fix, and then run a hose and see if it fixes it and then move forward with repairing the sub floor.
stephseattle is offline   Reply With Quote
Old 09-05-2016, 01:21 AM   #2
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Acryl is a thick liquid, silver colored which you can apply with a hand pump and good nozzle for careful application to the seams
There is a product called Dr. Tolleys which is great. It wicks into the tiniest seam/crack
Now, there is a thread here for a compilation of products useful for this perpetual maintenance.
Sounds like you need to drop the belly pan... It is almost guaranteed there are issues in there which can harm you. It is recommend (do not take this lightly) that proper respiratory, eye and clothing be used for protection. You may/will find remnants of mice, etc...which are bad for us humans...
If I can find the sealant thread I will post here...
Got it.. http://www.airforums.com/forums/f456...ry-116214.html
Peace and Blessings..
Channing
WBCCI# 30676
A/C Leaks When It Rains, Does Not Leak Condensation Steve Bryant Furnaces, Heaters, Fireplaces & Air Conditioning 2 06-16-2013 08:24 PM
AC leaks when it rains. AWCHIEF Furnaces, Heaters, Fireplaces & Air Conditioning 10 04-20-2013 06:06 AM
Kitchen hood vent leaks when it rains rogerdodger Roof Vents, Skylights & Fans 0 05-26-2010 11:35 AM
Kitchen hood vent leaks when it rains rogerdodger Leaks - Weatherstrips, Gaskets, Caulks & Sealants 0 05-20-2010 09:38 AM
1982 280 Leaks when it Rains k_rasmussen Classic Motorhomes 10 11-24-2006 08:04 PM
