Old 12-19-2015, 02:07 PM   #1
noremark's Avatar
1992 32' Excella
Elma , Washington
Images: 12
Is this a Belly Belt Leak?????
I had a door that was bent out of shape and not even close to sealing. That is now fixed. Looks like I also have another leak issue. Anyone else seen this in their unit. I want this fixed before the wood starts rotting out. I am ready to put a new carpet in but not till this gets dealt with. Thanks for any inputClick image for larger version
If you don't have the time to do it right the first time where you gona find the time to do it a second time.
noremark is offline   Reply With Quote
Old 12-19-2015, 02:40 PM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
To test it I would seal the door over with plastic and duck tape and let it dry. You can peek in every once and a while to see if it is dry. Once dry I would reseal the door and floor the side of the trailer with a hose. If the floor again show wetness it was not just the door. It may take some time for the floor to dry as that type of flooring holds a lot of water.
I think the door was to blame.
2004 Excursion 4x4
HowieE is online now   Reply With Quote
Old 12-19-2015, 04:30 PM   #3
dznf0g's Avatar
Oswego , Illinois
Have you removed and replaced the sealer above the rain gutters over the door and window?
Also the awning track is suspect. All common leaks which show up in that location.
-Rich-
Old 12-22-2015, 01:57 PM   #4
2014 25' Flying Cloud
los gatos , California
Something to check, make sure all fittings under the sink are tight and secure, including the water filter if you have one. I had this exact leak in my 2014 flying cloud 25RB. I just found another in the rear of the trailer. I'm open for suggetions for this one.
smr95032 is offline   Reply With Quote
Old 12-23-2015, 10:42 AM   #5
59' Globester
twolanehwy's Avatar
1959 18' "Footer"
1957 26' Overlander
san francisco , California
that is not original flooring / plywood.
I'd say PO put that and padding / carpet over your already rotted subfloor.
Good luck.
twolanehwy is offline   Reply With Quote
Old 12-23-2015, 11:32 AM   #6
1966 24' Tradewind
2005 22' Safari
Bastrop , Texas
Rivet
Good luck.
Our 2005 22 ft Safari came from the factory with OSB flooring , just like this one
dannydimitt is offline   Reply With Quote
Old 12-23-2015, 08:18 PM   #7
Rico2surf
Medford , Oregon
Not sure what year and model you have. Mine is a '73 27' Overlander w/ rear bath. My window has been leaking also. I have experimented with taping the window edges this winter since I had replace the window seal just last summer. I added more tape to the top hinged connection the next trip over to where i keep my AS. Greatly reduced the leaking . . . almost completely. So my feeling is to take the window out, the that hinged connection and reseal/reinstall. Then to the hose check to test. Probably will wait till summer though.
rico2surf is offline   Reply With Quote
Old 12-23-2015, 09:41 PM   #8
1974 Argosy 20
Kooskia , Idaho
Good luck.
OSB was used as the original flooring in the 80's and 90's. Not all, but some, and this one probably is one of them.
Old 12-23-2015, 10:34 PM   #9
59' Globester
twolanehwy's Avatar
1959 18' "Footer"
1957 26' Overlander
didn't know they would use such an inferior product. Not that plywood is much better if not coated but still better than OSB. If you go to a lumber supply that is the cheapest buy.
What year is this anyway, just curious.
Old 02-02-2016, 10:37 PM   #10
noremark's Avatar
1992 32' Excella
Elma , Washington
Images: 12
It is a 1992 Excella
Old 02-03-2016, 09:51 AM   #11
1998 30' Excella 1000
Livingston , Texas
My '98 has plywood.
Siegmann is offline   Reply With Quote
Belly Pan, No Belly Pan DryFly General Repair Forum 32 11-18-2017 08:43 PM
Leak in Belly Pan wombo Forum Admin, News and Member Account Info 1 06-08-2015 02:44 PM
Serpentine Belt Question -'92 454 - HELP fangthorpe Mechanics Corner - Engines, Transmission & More... 17 07-25-2010 10:26 AM
Leak in belly, by city water inlet...HELP rfield54 Fresh Water Systems 26 05-31-2010 06:20 PM
Belt replacement on 454 Gas Classic AccessMaster Airstream Motorhome Forums 12 05-03-2003 12:31 AM
