Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Leaks - Weatherstrips, Gaskets, Caulks & Sealants
Old 06-27-2011, 06:57 PM   #1
bennyg's Avatar
1973 23' Safari
New Albany , Indiana
Is there anyone who uses Trempro 636 & Sikaflex 221 on a 70's AS
Now that I am getting close to removing the shell off of "Ma", I want to seal the leaks 1st! I am fortunate in the fact that I have a fastenal next door to my work. They currently have trempro 636 in stock for $6 a tube with company discount. they do not have or carry sikaflex. My ? is.... are there places that I should use 636 instead of 221 and vice versa? If not I am trempro 636 all day long. Thanks, Ben
bennyg is offline   Reply With Quote
Old 06-27-2011, 07:21 PM   #2
x
XXXX , XXXX
Ben that's exactly what I used and where I bought it.
wasagachris is offline   Reply With Quote
Old 06-27-2011, 08:23 PM   #3
A W Warn's Avatar
2000 25' Safari
TremPro 635 is more appropriate than 636 for use on your trailer, due to resistance to vibration and better adhesion.
You can read the product specs at Tremco Urethane Sealants
Old 06-28-2011, 02:13 PM   #4
bennyg's Avatar
1973 23' Safari
thanks for info but fastenal didnt have 635 in stock and gave me a sweet deal on a case of 8 tubes, around $5 a tube after taxes. I dont think I will need 8 but I will remove all the old and reseal the whole trailer.
Old 07-29-2011, 08:12 PM   #5
surfpod's Avatar
1976 23' Safari
1962 22' Safari
1961 16' Bambi
Philly burbs , PA
Good luck on the Safari
Bennyg, I have also been using the 635 on my AS. I think it works well. I started a shell off resto of my 1976 23' Safari in April. I gutted it, new 3/4" ply floor. And rust proofed frame. I'm putting her back together with a new layout. I think the 23' is a perfect size to renovate. Good luck!
surfpod is offline   Reply With Quote
Old 07-29-2011, 08:16 PM   #6
Frank's Trailer Works's Avatar
Baltimore , Maryland
I use nothing BUT 636. It is never in stock and I always have to order it in(24 tubes at a time).
Frank's Trailer Works is offline   Reply With Quote
'97 Jeep GC / '70s Safari Tires my3sonsdad Tires 2 08-03-2011 07:32 AM
New Idea for '70s overhead lights - LED / Fantastic erock53 Lights - Interior & Exterior 12 07-15-2011 08:04 PM
Sikaflex 221 gray? AirHog Leaks - Weatherstrips, Gaskets, Caulks & Sealants 3 05-19-2011 12:22 PM
Calibrating late 70's Magic Chef oven blickcd Stoves, Ovens & Microwaves 2 04-02-2011 11:23 AM
'70s Safari bertro Trailer Values 1 01-26-2011 03:05 PM
