Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Leaks - Weatherstrips, Gaskets, Caulks & Sealants
Old 10-24-2009, 11:27 PM   #1
Profile:  1970 29' Ambassador
Euless , Texas
Is my weep hole on front window from PO
I have read that weep holes are original on AS motor homes only, not on trailers. However, I clearly have two on my front window (70 ambassador). Did PO create those weep holes. Rain water enters one of the holes and it seems like the only solution is to plug it. I will most likely use Vulkem. What do you think forum?
tx70amb is offline   Reply With Quote
Old 10-24-2009, 11:48 PM   #2
cameront120's Avatar
Profile:  1972 25' Tradewind
Does the window in question have a screen on the inside? If it's missing, those holes may have been caused by the screws that fastened the screen to the window frame. This was the case on my 1972 Tradewind. The resulting holes let water into the trailer. Not a great design, if done at the factory.
Cameron & the Labradors
Kai & Samm
North Vancouver, BC
Canada
AIR #11529
http://northvancouvermodern.blogspot.com/
Old 10-25-2009, 02:02 AM   #3
Commercial Vendor
Profile:  Corona , California
Only motorhomes had weep holes and covers, because of the sliding windows.
No Airstream trailer, ever built, had weep hole covers.
A previous owner obviously installed them on your trailer.
Why it was done, is the real question.
When you say front windows, do you mean "wing windows"?
If indeed it's the wing windows, then they must be double pane.
The double pane wing windows, unfortunately in time, if not kept properly sealed on the exterior, could collect water between the panes.
If that's the case a couple of drain holes could have been drilled at the bottom, on the outside, to allow the collection of water to escape.
See if the wing windows show a water line some what above the bottom of the glass.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 10-25-2009, 09:04 PM   #4
Euless , Texas
Thanks for input Cameron/Andy
Cameron, yes the front window has a screen, but there are no screws at the bottom corners to hold the screen in place. Andy, the weep holes were on the main front window that swings open and the question remains why PO would have done that. I solved the problem today my squeezing some Vulkem from the outside into the weep holes and that should solve that problem. Thanks for the advice to upgrade to the D shape weather strip. My 70 ambassador has all new weather stripping now except at the reefer access door. Thank you both for the reply. Onto the rear sag problem next weekend.
Old 10-25-2009, 10:12 PM   #5
You're still talking about the trailer, right?
My screen was attached by screws. Whether this was done in the factory of by a previous owner, I can't be sure. Vulkem solved the problem though!
Kai & Samm
North Vancouver, BC
Canada
AIR #11529
Old 10-25-2009, 10:51 PM   #6
Commercial Vendor
All double paned windows offered the same water leak problems.
Usually, at this point, they leak betwwen the glass becaue of a bad exterior gasket, that can easily be corrected with some Vulkem sealer.
Again, to each his own as to proper repairs.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 10-26-2009, 03:49 PM   #7
Euless , Texas
Cameron, my center front window screen is held in place with screws, but there are no screws in the bottome corners of the window. I do believe the weep holes were created by the PO. No matter at this point because I have sealed them up with Vulkem which seems to be keeping the current rain we are having out. Thank you and Andy for your input. By the way, the current center front window is single pane.
Old 10-27-2009, 02:00 AM   #8
Commercial Vendor
Since your front window is a single pane, then the weep holes were more than likely put there to let water out.
The question then becomes, how could water get into that window shelf.
The window gasket may be bad, the clearance light above it might be leaking, or the segments above that window, could be leaking.
You have not said anything about the gasket condition.
Andy Rogozinski
Inland RV Center
Corona, CA
Weep hole covers ralley General Motorhome Topics 10 11-08-2006 11:04 AM
Suggestions for Weep Hole Covers Chaplain Kent Classic Motorhomes 11 01-22-2006 08:44 AM
Exciting News-Weep Hole Covers and More!! Chaplain Kent General Motorhome Topics 3 01-17-2006 09:42 AM
Weep Hole Cover$ Chaplain Kent Classic Motorhomes 2 11-02-2005 10:09 AM
Weep hole covers wtrdawg General Motorhome Topics 3 03-30-2005 11:49 AM
