Old 06-12-2012, 08:38 AM   #29
ALUMINUM OBSSESSION
1993 34' Limited
Hamilton , Ontario
MY heart goes out to you!! I also have a roof water leak. I'm trying to find it also. Like myself, You might have to go to cam-am rv to have leaks checked and repaired with the 430r seal-tech machine. If all else fails get it fixed by the professionals. They have the necessary equipment to diagnos these problems.
william Haym is offline   Reply With Quote
Old 06-14-2012, 04:49 AM   #30
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Acryl-R Seam Sealer by Schnee-Moorehead, Inc, is another weapon you need in your leak battles. I think this is the stuff Airstream uses to seal seams.
I had a leak causing a wet floor at my curb side storage compartment, left side as you open the door. Like Becky said, soft plywood, ugh. So I ran my leak detector test. I rigged a garden hose with shower spray clamped to my step ladder and started squirting the compartment door. 30 minutes of water flow and no leak. Then I went 2 feet higher and repeated the test, no leak. Then I went to the bedroom window, sprayed for 30 minutes, still no leak. So I set up and sprayed above the bedroom window, but below the awning mount, no leak. Next spot I showered with water was the area above the awning and their she was. Water started coming in on the floor.
I used the Acryl-R and sealed the seams where the rear end cap sheets join the roof and side skins. I also sealed the vertical seams all the way down past the window. Acryl-R is a "thin" caulk that tends to run into the seam. The application tip is very small, and you can "squirt" it into the seam.
I won this small battle in the leak war. There are Airstreams that leak, and Airstreams that are gonna leak soon. It's part of the "fun" of owning one. Something to talk about on the caravan.
Add Acryl-R to your weapons stockpile. I got mine at the Airstream store.
David
Old 06-14-2012, 08:38 AM   #31
Splitrock's Avatar
Sioux Falls , South Dakota
The awning fabric was removed from my trailer when I bought it, and after I removed the roller, I found 5 missing rivets. The open holes were hidden by the roller.
Old 06-14-2012, 12:53 PM   #32
mefly2's Avatar
2015 25' FB Eddie Bauer
No excuse for missing rivets - hidden as well ...
Winterizing Tips niftypkg Winterizing, Storage, Carports & Covers 144 01-22-2009 07:06 AM
Talking to God on the plastic telephone. ArtStream Sinks, Showers & Toilets 8 08-27-2006 09:47 PM
God versus Computor... canny_banjo_man Off Topic Forum 2 03-04-2006 11:57 AM
