Old 07-01-2010, 08:24 PM   #1
Bex
1976 Argosy 28
Eckville, Lacombe County , 3025 TWP 400
Send a message via Skype™ to Bex
Inland RV gaskets and seals
I notice from the pics on Inland RV's site that they (the seals) have what looks like an adhesive backing strip. Is this to be used in addition to the 3M weather strip adhesive application? If its the same strip that I have seen on other gasket/seal suppliers sites it's probably a 3M adhesive seal. Why the need for the separate application?
Bex
TAC AB-1
A wise man once told me he wanted to stay fit enough to run a marathon on his hundredth birthday. Another said he wanted to be shot by a jealous husband on his, I'm with the latter. God bless you Richard.
Carpet Cleaning is what I do, it's not who I am.
Bex is offline   Reply With Quote
Old 07-01-2010, 08:52 PM   #2
georgezink's Avatar
1977 Argosy Minuet 6.0 Metre
Cape Coral , Florida
I used the gaskets from Inland RV and they worked fine without additional adhesive. Geo...
flcracker
georgezink is offline   Reply With Quote
Old 07-01-2010, 09:03 PM   #3
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
If you get the surface on your window frames really clean and degreased you won't need additional adhesive. I cleaned my frames with a scotchbrite buff in my dremel tool (only where the gasket sticks. I tried many different ways to get the old adhesive off and the Dremel was by far the fastest and best) and then wiped with lacquer thinner. Once I peeled and stuck the gasket in place it was there. You might want to use just a dab in the corners, but I mitered mine and didn't. The gaskets worked great and fixed my window leaks.
Old 07-01-2010, 09:20 PM   #4
Bex
1976 Argosy 28
Thanks!
I wonder why the instruction Andy gives out have us putting a bead of adhesive?
Maybe the seals come in both flavours?
Bex
Old 07-01-2010, 09:54 PM   #5
Originally Posted by Bex View Post
Thanks!
Bex
Why do cars use adhesive on their door gaskets?
They do not rely on the double sided tape either.
The adhesive "GUARANTEES" that the gasket will "never" come loose or fall off.
I cannot say the same for just the double sided tape.
But, as always. it's the owners choice.
We recommend what we feel is the "very best" fail proof method of gasket installation.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 07-01-2010, 10:03 PM   #6
BIGED52's Avatar
1967 22' Safari
MILAN , Illinois
No different flavors
Andy would be the first to tell you to get the best seal you can and not to cut the gaskets in the corners. To have the seals last the longest and stay in place the adhesive is your added insurance. Andy would never steer you wrong. Over kill maybe but wrong never! Happy Trails, Ed
1967 Safari Twin "Landshark" w/International trim package
1999 GMC Sierra 1500 SLT
FORUMS MEMBER SINCE 12/16/2004
AIR#7110
"My tire was thumping, I thought it was flat!
When I looked at the tire... I noticed your CAT!"
Burma Shave
BIGED52 is offline   Reply With Quote
Old 07-02-2010, 06:27 AM   #7
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
We used the black adhesive on all of the window and door "D" seals. Seemed like good additional sticking insurance instead of just using the double sided tape that came on the seals. It really doesn't add that much time or expense to the installation.
Chris
Old 07-02-2010, 06:34 AM   #8
Bex
1976 Argosy 28
Originally Posted by BIGED52 View Post
Andy would never steer you wrong. Ed
I realise that, and thanks!
Andy, I am still waiting for you to respond to my order request through your site.
Bex
TAC AB-1
Old 07-02-2010, 06:38 AM   #9
Iwannagocamping
Dakota's Dad's Avatar
Rineyville , Kentucky
Considering how hard it was to get the original gaskets off, I KNOW they won't fail with the black adhesive. Unless you are really wasteful, 1 tube will do the whole trailer, twice. 31' here, we did all windows, door, and both roof vents.
See our blog here on how two RV/AS rookies tackle a 1979 Sovereign resto!!
Just the photos.. (sometimes you don't need the blog, just a picture worth a thousand words..)
1979 Sovereign International
2004 Ford Expedition Eddie Bauer
2 Golden Retrievers
Air #36788
TAC#3179
WBCCI #1265
Dakota's Dad is offline   Reply With Quote
Old 07-25-2011, 01:15 PM   #10
1976 24' Argosy 24
Milford , New Jersey
Andy, i know this is an old post, but do you recommend the same use of sealant for the door gasket? It also has the sticky tape. Do you apply the sealant over the sticky tape? After removing the white paper of course. I have not been able to find a copy of your instructions, thanksfor your time. George
Gkiesel is offline   Reply With Quote
Old 07-25-2011, 02:10 PM   #11
George.
Your entrance door uses a triangulat gasket, that has the white sticky tape on it as well.
Don't depend on it holding anything.
Use the 3M black super weatherstrip adhesive.
Andy Rogozinski
Inland RV Center
Corona, CA
Where to buy seals/gaskets (in Canada) Bex Leaks - Weatherstrips, Gaskets, Caulks & Sealants 6 06-29-2010 10:01 PM
DIY Window tinting & new seals/gaskets Maryw164 Windows & Screens 5 06-04-2009 03:37 PM
What about my gaskets!? anami Cleaning, Stripping & Polishing 0 03-03-2009 04:12 PM
Window Gaskets Robin Stone Windows & Screens 6 03-06-2008 04:11 PM
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
