Old 03-22-2016, 07:05 PM   #1
1972 27' Overlander
Nunica , Michigan
I can't find where this leak is coming from
Hi. I just bought a 1972 overlander and I can't find the source of the leak by the front door and the window next to the front door. I've put new seals on the door and all but the back window. I've put a new cap on the roof vent and calked around it. Any ideas would be great thanks.
Mberg130 is offline   Reply With Quote
Old 03-22-2016, 07:25 PM   #2
larry b's Avatar
1975 31' Sovereign
howell , Michigan
Join the club!
Just guessing- what about the awning rail?
larry b is offline   Reply With Quote
Old 03-22-2016, 07:36 PM   #3
TheGreatleys's Avatar
1974 27' Overlander
Baltimore , Maryland
Have any of the windows been replaced with Olympic rivets? My lower Vista views had leaking Olympic rivets on both sides.
TheGreatleys is offline   Reply With Quote
Old 04-05-2016, 07:22 PM   #4
1972 27' Overlander
Nunica , Michigan
The front passenger side window was replaces and I can see the rivets leaking. Should I drill them our and replace them? How do I stop them from leaking?
Old 04-05-2016, 07:31 PM   #5
GMFL's Avatar
2014 23' International
Dadeville , Alabama
I would say awning rail
Old 04-05-2016, 07:59 PM   #6
dznf0g's Avatar
Oswego , Illinois
If they are not loose, use Captain Tolley ' s Creaping Crack Cure. Works well on rivets.
-Rich-
Trying to find Grandpa's Old Airstream...can I find it with Serial Number?? Jakescheid Our Community 13 11-22-2011 11:01 AM
The welder is coming, the welder is coming... Safari Tim General Interior Topics 13 09-01-2006 10:00 AM
Can't find water leak - near fresh water tank. Loren Fresh Water Systems 16 01-01-2006 05:40 PM
The Airstreams are Coming!! The Airstreams are Coming!! j54mark Airstream "In the News" 7 07-07-2005 07:06 AM
Can Not Find Leak Help! Rennegarbe1 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 10 05-12-2003 04:08 PM
