Old 03-08-2012, 03:11 PM   #1
rbs
rbs's Avatar
2015 30' Classic
Decatur , Illinois
How to store Acryl-R & Pump
I thought I had read where a person can use Acryl-R with the pump and simply plug the outlet and store with the pump attached, but cannot find where I had read it. Can someone tell me how they store the unused Acryl-R?
Rod
rbs is offline   Reply With Quote
Old 03-08-2012, 04:38 PM   #2
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
Good question. I have the can and the pump, but haven't used it yet. I believe Acryl-R has a shelf life of 18 months, though I suspect it is good after that for quite a while.
Gene
Old 03-08-2012, 04:54 PM   #3
Baltimore , Maryland
I just put mine on the shelf. I don't even put the tip in. I however go through a can every other month.
Old 03-08-2012, 05:26 PM   #4
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
I have saved cans of Acryl-R and dispenser units by putting the supplied plug in the tip, and using a finger from a rubber glove put over the tip. A rubber band around the finger will keep it there. Leave the dispenser in the can as well.
Old 03-08-2012, 05:40 PM   #5
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
I took the pump off, pumped mineral spirits thru, put pin in nozzle, cleaned cap, resealed, and put it back on the shelf. Hope it werks 'cuz theres more to do this Spring.
W. H. Auden
"The hardest thing about Airstreaming, clearing your head and accepting how others feel itís supposed to be done"Ö..
Amanamus
"Tahawus"
Old 03-08-2012, 06:11 PM   #6
1993 21' Sovereign
Bob, please let us know if it works. Both Frank and I use the Acryl-R enough that would be more trouble than it's worth. I can use some, store it for 3-4 weeks, then go through 2 or more cans in a week.
Old 03-08-2012, 06:14 PM   #7
2005 22' International CCD
Aliso Viejo , California
I store it on the shelf without the pin in it. I just prick the nozzle with a small nail and am good to go. I've been using the same can for over a year. No problems.
Davern1 is offline   Reply With Quote
Old 03-08-2012, 07:54 PM   #8
... if it get a bit too viscus, add a few drops of xylene.
Old 03-09-2012, 08:34 AM   #9
Master of Universe
Gene's Avatar
Would the pros tell us how to apply it from the pump since some of us haven't used the pump yet? Does it come out in a bead and how do you hold the can?
Gene
Old 03-09-2012, 02:27 PM   #10
Gene you are just going to have to learn. I suggest starting as far from eye level as possible and by the time you get to eye level, you will be a pro. If you mess up, you can just melt it away with some solvent and go again. Have fun.
Old 03-09-2012, 04:54 PM   #11
1993 21' Sovereign
What Frank said.
Seriously, it's an acquired talent, you just have to keep practicing. I can't run a decent bead of caulk to save my life, but I can do pretty good with the Acryl-R.
Old 03-09-2012, 05:07 PM   #12
Let's hear it folks......It's the Frank & Terry Shoe.
W. H. Auden
Amanamus
"Tahawus"
Old 03-09-2012, 06:29 PM   #13
Master of Universe
Gene's Avatar
I thought Frank and Terry would have some professional tricks to share. I am pretty bad with beads too, so at least I'm as good as Terry.
Gene
Old 04-11-2017, 02:21 PM   #14
KJRitchie's Avatar
2008 25' Classic
Full Time , Texas
I'm attempting to use Acryl with the dispenser. New can's expiry date is 6/16. It seems kinda thick and when I tried to use it doesn't flow well. I made a mess of my first seam.
Can I add Xylene to it? How fluid should it be to match fresh Acryl? Do you mix the Xylene with a stick?
Should I just pump out the Acryl out of the dispenser until it doesn't pump then put it back in the can or should I thoroughly clean it with Xylene before using it again.
Do you normally apply Acryl with the dispenser upstream so it lays behind the dispenser nozzle?
Kelvin
Road Trips 2012 & Real Estate Gene On The Road... 716 02-24-2015 12:44 PM
Converting a Classic to CNG t7389sg Classic Motorhomes 9 06-23-2012 11:53 PM
How to reseal windows 92landyacht Land Yacht/Legacy Motorhomes 8 04-03-2012 06:16 AM
Help towing an Airstream Safari from AZ to CA drmittens On The Road... 4 03-08-2012 11:45 PM
How to buy a used AS??? sophiefox Buyer Guidelines 4 03-08-2012 12:49 PM
