Old 02-24-2015, 04:38 PM   #1
1988 29' Excella
Plant City , Florida
How to remove silicone caulk
I got on top of my trailer today to seal the fantastic fan and found a lot of silicone on the seam where the roof panels end and the end cap starts is there anything that Will remove the silicone after I scrape off as much as I can first ?
Joe
wjcwill is offline   Reply With Quote
Old 02-24-2015, 04:49 PM   #2
1973 25' Tradewind
Augusta , Georgia
I used the silicon caulk remover that is available form Vintage Trailer Supply. Was very pleased with the performance (& service from VTS).
dennis
DGJackson is offline   Reply With Quote
Old 02-24-2015, 04:54 PM   #3
King of the Zebra Speedo
Panama Red's Avatar
Obrien , Florida
I have incredible amounts of silicone on my trailer from the PO. THe remover I purchased from Home Depot just didn't work very well. It did a heck of a job removing the clear coat, not so great at the silicone. Will have to check into VTS's remover...
-Red, desperate to de-siliconize...
Somebody ought to clean these windows. There is a tremendous buildup of gook all over them...
Panama Red is offline   Reply With Quote
Old 02-24-2015, 04:59 PM   #4
Top
Always learning
Top's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Top
Drape a rag soaked in mineral spirits over the silicone for about 20 min and it will soften it up and make it easy to remove.
Lance
Top is offline   Reply With Quote
Old 02-24-2015, 05:06 PM   #5
1988 29' Excella
I will look at VTS also.
Joe
Old 02-24-2015, 07:00 PM   #6
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
You can get Malco Cosmoline Remover. A couple minutes' rubbing with a cloth soaked in the stuff, and the silicone will wrinkle up and scrape off easily.
Old 02-25-2015, 12:08 PM   #7
Wise Elder
Jammer's Avatar
2010 30' Classic
Joe
Hi Joe
There is no easy answer for this, and the difficulty of removal and effectiveness of the various products will vary from one project to the next. Whether due to age of the silicone, care taken in application, or formulation of the product used, I do not know.
I have had the best results with a heat gun and an improvised wooden scraper. A paint stir stick or a doorframe shim will work. Plastic scrapers will soften in the heat and metal ones will scratch the aluminum. Care must be taken not to damage or ignite anything nearby.
I have used the silicone remover sold by VTS. While effective, it is slow going and will not work especially well on thick applications of silicone. It is also expensive.
Old 02-25-2015, 02:39 PM   #8
Dallas Center , Iowa
I too have used a heat gun on silicone but not on my AS. The application was on metal ducting that had been slip-sealed with silicone as they were joined together. It loosened them up in no time and was able to disassemble very easily. As I recall the vapors were toxic so ventilation may be appropriate. It was somewhat messy. Good luck.
Earthcreeper is offline   Reply With Quote
Old 02-25-2015, 03:05 PM   #9
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
My trailer required a lot of elbow grease, careful mechanical removable with many straight edge razor blades.
1/2 Ton 4WD Truck, 72 Sovereign Hensley Arrow
Old 02-25-2015, 03:09 PM   #10
ShinyPete
ShinyPete's Avatar
2014 27' Flying Cloud
Bushnell , Florida
WJC - what year is your coach? If it's a relatively newer Airstream you may be seeing factory roof caulk. Is it white and silicone "feeling", and alongside as well as inside the "panel gaps"? I discovered the shiny white caulk on the roof seams of our 2014 FC 27fb is factory and while not silicone per se it is silicone like.....in that nothing else sticks to it. It may be Sikaflex (polyurethane) or Dicor or something like that............
If your coach is say 10 years old or older and the caulk looks like a previous owners "the bigger the glob the better the job" project over the top of everything up there then it's probably silicone.......
ShinyPete is offline   Reply With Quote
Old 02-25-2015, 03:17 PM   #11
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
I despise silicone calking. Cant stand the stuff. It should ONLY be used INSIDE the joint where two pieces lap, never to fill or seal an exterior gap.
Eventually this stuff starts peeling and it looks like CRAP, it is hard to fix, and it is just bad. I would sooner use latex as silicone for seam sealing.
Old 02-25-2015, 03:37 PM   #12
Panama Red's Avatar
Obrien , Florida
I will only use Vulkem, or an equivalent type caulk. I hate the silicone with a passion. I can take a die grinder with a mild abrasive wheel, get the outer layer of the old Vulkem off, then wipe with mineral spirits to remove the rest... So much nicer when you have to reseal.
-Red, anti-silicone...
Old 02-25-2015, 04:31 PM   #13
1988 29' Excella
I have a 88 Excella 29' my father owned the AS before me and gave it to me last year when he stopped traveling he is the one that put the silicone on it there is some also on the rub rails and over some of the windows also my worry is if I don't clean off the silicone on the roof seams good enough the new sealant will not stick and reseal the seam. It is not leaking now
Old 02-25-2015, 04:33 PM   #14
lewster's Avatar
Naples, FL , Hood River, OR
Silicone should NEVER BE USED ON AN RV!!!!!!!! ANYWHERE!!!!
PERIOD.
Lew Farber
AM Solar Certified Installation Center
Lifeline Batteries**Magnum Inverters
541-490-6357
Caulk caulk and more caulk amazingwoody Leaks - Weatherstrips, Gaskets, Caulks & Sealants 28 03-23-2015 10:16 AM
Silicone or not to silicone michele19 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 2 07-29-2013 02:37 PM
Silicone / No Silicone for Fantastic fan polarlyse Roof Vents, Skylights & Fans 17 09-01-2010 01:30 PM
