05-12-2008, 06:04 PM
MyFirstStreamer
Indiana
, Indiana
How to remove old caulk, glue and crud?
I am about to reseal doors and windows. I tried goof-off and Lift-off in an attempt to scape out the old caulk, glue etc... WD40 works OK for caulk but can get a handle on the old glue and adhesives used to afix old seals etc... Anybody have a trick for scaping out old glue and years if accumulated crud around doors and windows? Tks, Z..
05-12-2008, 06:06 PM
, At Large
One of the tool distributors sells an item that is basically a very large round eraser that coes into the chuck of your electric drill. It removes stickers, pinstripes, and adhesives, as well as adhesive-backed stuff. Supposed to be non-marring.
05-12-2008, 06:14 PM
1963 22' Safari
2020 27' Globetrotter
State of
3m makes on and it worked very well on a fiberglass shell on a fleet vehicle we worked on, never tried it on metal, but assume if its safe for fiberglass it is safe for metal, though you'd need to be careful the area doesn't get too hot, tons of friction. You can get it through almost any auto paint supply house. We tried caulking remover from Home Depot and it worked well, as well as xylol (or zylol) solvent from the hardware store took care of some of it as well. Plastic puddy knife can also come in very handy.
05-12-2008, 06:16 PM
Rivet Monster
1975 31' Sovereign
1980 31' Excella II
Sprung Leak
I used a brass or plastic brush wheel in the drill, then the dremel to get the stuff off of the two windows that I have done so far.
Aaron
WBCCI #XXXX AIR #2495
05-12-2008, 06:17 PM
MyFirstStreamer
Indiana
, Indiana
Thanks! I am going to pick that up tomorrow. -Z
05-12-2008, 06:50 PM
West of Fort Worth
3M makes a caulking remover that works great on silicone. It comes in a red and white(?) bottle that looks like a bottle of school glue. Apply it, let it sit for a couple of hours, caulking comes off in a string.
AIR #15800
"Wimpy" 1/2 ton 2002 GMC Sierra 4X4 Z-71 Gasser
2000 Safari SS 25'
05-12-2008, 06:57 PM
1972 25' Tradewind
North Vancouver
, British Columbia
Do you know if it works on Vulkem & Sikaflex?
North Vancouver, BC
05-12-2008, 07:17 PM
Loganville
On an earlier thread I read where somebody used De-solv-it for removing the glues from gaskets and weather stripping. I used it last weekend and it worked well on the glue for the gaskets, but not for the weather stripping on the screen door. From just trying different things such as goof of, steel wool, 3-M scouring pads, lots of elbow grease and De-Solv-it I got most of it off but not all of it. I also burned out my dremel using a wire brush with it. I still have a little bit to go so if anybody else knows of anything that works please let me know. I am speaking about the adhesive for the weather stripping for the screen door.
SIU Bound
Brian
05-12-2008, 07:21 PM
1963 22' Safari
State of
xylol/xylene works great even on vulkem, even old stuff. not sure about clear coats though.
05-12-2008, 07:29 PM
Baltimore
, Maryland
MEK... it is the bomb. Cleans aluminum instantly and takes off any foreign substance. It dries very quick and the fumes make you smile from ear to ear. MEK, I highly recommend it. I just bought a 5 gallon of it specifically to clean up before and after polishing.
05-12-2008, 07:34 PM
1975 25' Tradewind
Albany
[quote=SIU Bound]On an earlier thread I read where somebody used De-solv-it for removing the glues from gaskets and weather stripping. I used it last weekend and it worked well on the glue for the gaskets, but not for the weather stripping on the screen door. From just trying different things such as goof of, steel wool, 3-M scouring pads, lots of elbow grease and De-Solv-it I got most of it off but not all of it. I also burned out my dremel using a wire brush with it. I still have a little bit to go so if anybody else knows of anything that works please let me know. I am speaking about the adhesive for the weather stripping for the screen door.
SIU Bound
Brian
I used a presure washer on my screendoor and it came right off. This was pretty old so had been on there for a long time. Rancher Jim
05-12-2008, 09:35 PM
West of Fort Worth
I don't know that. It is called Caulk remover, I have only tried it on silicone. It works great for that.
Dave
AIR #15800
2000 Safari SS 25'
05-12-2008, 09:57 PM
flint
, Michigan
I can recommend the stuff I got at Ace Hardware called "Contractor" or something similar that works well. It really melts the clear silicon the the PO loved so much.
05-12-2008, 10:04 PM
1967 22' Safari
Deer Park
I replaced all my window gaskets last year. I can't remember where I got the information but the thread I read to replace window gaskets said to use acetone to remove the glue after you scrape most of the gasket material off. It worked fine for me and its cheap. Use gloves!
05-12-2008, 10:25 PM
More than one rivet loose
Los Alamos
You should really be using a respirator. It will cause nervious system damage over time.
Michelle TAC MT-0
Sarah, Snowball
05-12-2008, 10:35 PM
418
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley
MEK:
METHYL ETHYL KETONE
05-13-2008, 04:16 AM
Baltimore
, Maryland
Sorry, I was making a joke.
Folks MEK is at the very top of the solvent chain. If MEK does not remove it, it is not coming off. Not only will the fumes get you high as a kite, but the solvent actually will seep into your skin. Gloves are highly recommended too. MEK is acetone on steroids. Use it with caution. Wear gloves and a resperator that has a chemical filter in it. Most resperators come with filters for organic filter only, so a trip to a good auto body paint store or a real paint store like Sherwin Williams might be needed. Do not put it in a bag and inhale, that would be very bad for you.
05-13-2008, 04:17 AM
1955 22' Safari
Great Lake State
This is what the Scorecard.com has to say about METHYL ETHYL KETONE (MEK).
METHYL ETHYL KETONE
05-13-2008, 04:18 AM
Baltimore
, Maryland
You must have a material data safety log in your shop... karma to you for that.
05-13-2008, 09:59 AM
1965 20' Globetrotter
1956 22' Caravanner
Mendon
, Massachusetts
aircraft stripper
Aircraft Stripper works great but wear a respirator. I bought a gallon to remove some zolatone and then found that it worked great for removing just about anything else.
Great stuff, but make sure to wear gloves (chemical resistant) and glasses.
Doug
56' Caravanner 'The Broomstick'
