MEK... it is the bomb. Cleans aluminum instantly and takes off any foreign substance. It dries very quick and the fumes make you smile from ear to ear. MEK, I highly recommend it. I just bought a 5 gallon of it specifically to clean up before and after polishing.
You should really be using a respirator. It will cause nervious system damage over time.
Michelle
I'm not afraid I learned to drive in Washington, DC
Sarah
Ruby, (05 BMW R1200RT) serviced and put to bed for the winter
Daisy, (06 Diesel F-250 w/Tow Command)
Butter Cup, (06 Classic 31 w/dinette, solar) http://Michelles-Adventures.US
Sorry, I was making a joke.
Folks MEK is at the very top of the solvent chain. If MEK does not remove it, it is not coming off. Not only will the fumes get you high as a kite, but the solvent actually will seep into your skin. Gloves are highly recommended too. MEK is acetone on steroids. Use it with caution. Wear gloves and a resperator that has a chemical filter in it. Most resperators come with filters for organic filter only, so a trip to a good auto body paint store or a real paint store like Sherwin Williams might be needed. Do not put it in a bag and inhale, that would be very bad for you.
Aircraft Stripper works great but wear a respirator. I bought a gallon to remove some zolatone and then found that it worked great for removing just about anything else.
Great stuff, but make sure to wear gloves (chemical resistant) and glasses.
Doug
65' Globetrotter 'The Otter'
56' Caravanner 'The Broomstick'
For Silicone, the only product I have found so far is Digesil Gel Stripper.
It will soften up the Silicone, to where it sort od shrivels, and is then removeable by peeling it off the aluminum. Expensive, but worth it.
MEK isn't available in CA, I believe. Hearing how harmful to biology it is, I wouldn't probably buy it.
Maybe this is common knowledge on this Forum, but the Home Depot folks recommended Pure Citrus Orange Air Freshener to remove adhesive residue from the old weatherstripping. I was skeptical, but it really works! You can wipe most of it off with a paper towel. Just a little further work with a wire brush and the residue is gone.
I have had reasonable sucess removing the remains of old Vulkem using paint thinner or lacquer thinner. I have typically scraped off what I could with a putty knife or a plastic scraper. A little elbow grease along with the thinner does pretty well for the last little bit.
