Old 06-05-2007, 11:20 AM   #1
1964 22' Safari
kootenays , BC
how much weight can sit on top of an airstream?
HI, I have to seal the top of my airstream up, we don't have scaffolding.
Can a 170 pound man sit on top of it to apply the sealant without damaging the airstream?
Would it better if someone who was 115 lbs was up there?
Any last minute tips on applying the sealant? We have parbond and trempro.
Thank you everyone.
fancy pants is offline   Reply With Quote
Old 06-05-2007, 11:38 AM   #2
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
Send a message via Yahoo to Boondocker
You should be fine if you can stay near the seams as much as possible. If you can figure out a way to spread out your weight that is better yet.
Rodney
Visit my photography page
and the
Favorite camp grounds project map
My Blog
(The artist formerly known as General Disarray)
Boondocker is offline   Reply With Quote
Old 06-05-2007, 11:38 AM   #3
Images: 59
Definitely keep weight below 120 lbs. If your teenager weighs more than that, take away his IPod.
No time to be playing tunes when there's work to be done!
Old 06-05-2007, 01:06 PM   #4
Tarheel's Avatar
2001 34' Limited S/O
Moyock , North Carolina
Images: 21
there is a photo somewhere of over 20 men perched atop an airstream with no structural damge to the unit.
Keep the shiny side up.
WBCCI # 348
Past Region 3 President
Past President Tidewater Unit 111
Rick Bell in "Silverbell"
Tarheel is offline   Reply With Quote
Old 06-05-2007, 01:59 PM   #5
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
A piece of carpet wrapped around a 2ft by 2 ft 5/8 in plywood makes it easier on your knees and the airstream. It should be placed above a bow if possible. ( Rivets will show you where the bows go over the top of the unit.)
Old 06-05-2007, 02:20 PM   #6
2005 22' International CCD
Buckhorn , Ontario
Images: 59
Send a message via Skype™ to GT1963
HI Fancy Pants....love the name
I have a 63 GT and have to do the same (if it would ever stop raining)
This 63 has in it's seams - the original vulkum - that is almost in some sections to a powder substance. someones lovely attempt with some black tar stuff in a few other seams - and of course the aluminum parbon - muchly over top of all the other stuff - which most knows that it will not have a good seal to crap.
A big deterant is people don't want to take the time to get the other stuff off and out first - try to get right down to pliable vulkem if any left. Use a picking tool (a recent one I just bought is the gasget and o-ring remover tool from the automotive trade) works perfect.
Recently I have used parbon and more recently I thought I would try the alcoa gutter seal - simply because it said in the description wicks into cracks.
Unless you use a fine nosle on the parbon tube you just don't get it in the crack of the seams - so most ends up out side along the seam line. You can tape it off like some do but you still have a raised bead along the seam. I don't like that look at all.
So I tried the gutter seal in a few places like on the inside on the olympic rivets we just installed the marke lights with. And around the edges of the marker lights because there is an ever so slight cup from the shell to the base. Applied a good bead, waited about 3 minutes or so and then wiped along the edge with a rage sprayed with wd40 - it takes ONLY the excess that is on the outer portion of the edge or (soon to be seams).
I am amazed at how this stuff really wicks into the space that harbors the "rain".
But the key to any job well done - is the Preparation!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
So if you do not want to have your seams leak - take the time to get the crap out of them first. - If you ever have your skins off check all the seams inside too. Ours are okay except the window frame seams - have pretty much dried out. so I will need to do those inside and out.
With the amount of rain we have had I feel like I live in BC - how do you get anything done with all the rain. I know a nice big Garage I only wish.
Oh yes to get to your question - stick to the main ribs - but you can reach most of the trailer by ladder - if you have the no slip ladders and lay up to the seams. I use a foam floor puzzle type thing that I rest between the ladder and the shell works great.
If you are lucky like us right now - you can just pop up through either the skylight or if you are thin enough - I am 170 too and I can make it up through the vent fan believe it or not You can reach a lot of seams from up there.
Don't forget your awning rail - always a big source of leaking.
happy sealing - I will be thinking of you when I am doing mine (like I said as soon as it stops raining)
Everything will be alright in the end. If it is not alright now, then it is not the end.
GT1963 is offline   Reply With Quote
Old 06-05-2007, 02:54 PM   #7
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
BTW markdoane is joking
Originally Posted by markdoane
Definitely keep weight below 120 lbs. ...
I, at first, worried about walking around on top of my Overlander. But after no ill effects from either A/C service or solardome replacement, I'm comfortable getting on top of my Airstream.
Stay off the endcaps, though.
Tom
Old 06-05-2007, 03:37 PM   #8
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Two box trucks
There's a neat picture somewhere on this blog of two guys polishing an Airstream by driving it between two box trucks and stretching a ladder or ramp between the trucks, then lying down and doing the "Boys Gone Wild with Cyclos" routine. If you know someone who has a business with a couple of trucks, that's an alternative.
Paula F.
Foiled Again is online now   Reply With Quote
Old 06-05-2007, 05:05 PM   #9
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
Thumbs up Hey! That's me!
Paula F.
For more pics check out my polishing gallery
Shari
Old 06-05-2007, 05:41 PM   #10
flyfisher's Avatar
2004 30' Classic
Field and Stream , PA & MT
Heck, yes, it's always better if you can get your wife up there rather than yourself. Why Ask?
Seriously, if you stay on the rivet lines, I think you should be okay.
John
Flyfisher
flyfisher is offline   Reply With Quote
Old 06-05-2007, 07:32 PM   #11
lewster's Avatar
Naples, FL , Hood River, OR
GT6921,
Try Acryl-R for your small seam sealing chores. It is what the factory now uses, comes with it's own applicator gun, is re-fillable, wicks into the seams and stays pliable after curing. What else would one want in a fine point sealer?
Old 06-05-2007, 07:35 PM   #12
Buckhorn , Ontario
Images: 59
Originally Posted by lewster
GT6921,
ooooohhhh that sounds seriously delicious - where might I pick up that product here in central east Ontario???? any ideas.
Old 06-06-2007, 10:15 AM   #13
Thank you everyone.
Many years ago, to prove a point, the Airstream factory placed 30 men on the roof of a 30 foot trailer, resulting in no damage or water leaks, much to the amazement of those watching with open mouths.
Walking on the roof is not a big deal. However, "DO NOT" go forward or rearward of the awning rail. If you do, you will have instant sheet metal damage.
Old 06-06-2007, 10:57 AM   #14
I bought the applicator and refill from the shop at Airstream, Inc. :: Travel in Style
This is an excellent piece of kit. For more information, just type "Acryl-R" into the search box at the top of the screen.
Nick
Nick Crowhurst, Excella 25 1988, Dodge Ram 2500 Cummins Diesel. England in summer, USA in winter.
"The price of freedom is eternal maintenance."
nickcrowhurst is offline   Reply With Quote
2002 'Deam' Designed Airstream. Andy R Community Polls 48 04-23-2010 02:08 PM
'78 airstream trailer lbf78SvgnInt31 General Interior Topics 4 10-21-2006 12:09 PM
Airstream T-Shirts jcanavera Our Community 15 08-15-2002 10:14 PM
Airstream Related List Servers Andy R Link Archive 0 02-22-2002 02:05 PM
AirstreamTrailers.com - Airstream Link Library Andy R Link Archive 0 02-22-2002 01:31 PM
