Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Leaks - Weatherstrips, Gaskets, Caulks & Sealants
Old 06-27-2008, 10:00 PM   #1
rideair
Profile:
How much pressure
I plan to do a "leak test" on my trailer soon. A buddy of mine has all the stuff needed to do such a test. He ask, "How much pressure you want?" "1/2 psi?"
He joke and said, "I can go to 10psi like I do when we test jet airplanes?" I think he said around 9.2psi is equal to 25K feet, but don't hold me to it. I can't see my Airstream flying at 25k feet, but it would be cool.
So, the question is, "How much pressure should be needed to test for leaks?"
Paul Waddell
Region 2 VAC Guy
WDCU "Past Prez" (In the words of Richard Nixon "You won't have me to kick around anymore!")
rideair is offline   Reply With Quote
Old 06-28-2008, 05:54 AM   #2
markdoane
Profile:  , Minnesota
Images: 59
Wow! 10 psi would be cool, but I think it would blow the fluids out of your drain traps. Not to mention blowing the windows out of their frames.
I'd see if she holds 1/2 psi. Thats enough to find any leaks.
Non-contributing deadbeat.
Old 06-28-2008, 09:52 AM   #3
easyride
Profile:  1977 27' Overlander
naples , Florida
Are you trying to test the shell for leaks,the water,or gas?
easyride is offline   Reply With Quote
Old 06-28-2008, 10:13 AM   #4
tpi
Profile:  2005 25' Safari
Trabuco Canyon , California
Be careful here..even a half PSI would push on a flimsy UV damaged 17 inch square skylight with 140 lbs pressure. At 10 PSI I can see lots of points of failure
tpi is offline   Reply With Quote
Old 06-28-2008, 11:55 AM   #5
Inland RV Center, In
Commercial Vendor
Profile:  Corona , California
First of all, I sort of disagree with that leak test method. It does have it's values, but it also has severe drawbacks.
If you use more than 1/2 psi, you will cause leaks where you do not have leaks now.
First of all, an Airstream is not a submarine, and neither is your home.
If you used that test method on your home, you would find leaks galore, and the same is for your Airstream. As an example, your window gaskets are designed to handle pressure from the exterior of your trailer. not the interior.
Some areas of the trailer, are like your home. Of course they leak. That does not mean that water will enter.
One of the biggest leaks you will find, that your pressure system will not show, is the sewer vent pipe covers.
Any test method or system, should be carefully used, and interpreted, of what you found, and why.
Use considerable caution with the pressure system.
Inlandrv.com
The largest "Vintage"Airstream parts headquarters on the planet.
Home of the X-Stream Makeover
800-8777311
Old 06-28-2008, 01:04 PM   #6
Jim Foster
Jim Foster
Jim Foster's Avatar
Profile:  1965 17' Caravel
Walnut Grove , California
I don't think I would apply air pressure to the inside of my Airstream.
Like Andy says, Airstreams are built to keep water etc. out, not in. There are so may places that items go through the skin and floor. Wires for lights, lines for propane and plumbing. I don't think they put any type of air tight seal around the perimeter of the floor.
If you do give it a try, and you don't do any damage, I think all you are going to find is that your unit will not hold air pressure. It's an Airstream, not an Air Liner. You will still not know where the air is escaping.
I think it will all go our the roof vent as you put it in anyway. And if you tape that down, it will ust escape somewhere else.
Old 06-28-2008, 01:18 PM   #7
HowieE
HowieE's Avatar
Profile:  1991 34' Excella
Princeton , New Jersey
Images: 11
Paul
It is not pressure you need it is volume. There is no way you can seal an Airstream enough to run a static air test. If you do seal the windows, door, roof vents, back and top of ref., you still have to be concerned with the floor and all it penetrations.
Yes if you could seal everything to a reasonable condition and started introducing a controllable volume of air you run the risk of doing damage as you increase the volume of air chasing a leak that may not be there.
WBCCI 12156 AIR 3144 WDC unit
1997 6.5 Diesel Chevy 2500 See my pages mysite.verizon.net/vze54tx9/
and mysite.verizon.net/vze54tx9/kayak/
1991 34 ft. Excello +110,000 miles, new laminated flooring, new upholstery, new 3200 lbs axles
Old 06-28-2008, 01:34 PM   #8
2airishuman
2airishuman's Avatar
Profile:
yeah, i agree with howieE...
it's about volumes of air.
that's why NO SPECIAL EQUIPMENT is needed really. a large volume vacuum cleaner can provide enough air for testing...
it seems the 'seal tech' process may have some value, in specific situations or with some units, but
the bigger question is...
WHY r u considering this process?
-are there water leaks when it rains and the trailer is parked?
-are there water leaks when it rains and the trailer is in tow?
i can't imagine any good reason to test an old trailer that is IN use,
unless there is some odd water entry issue that cannot be solved otherwise.
besides after the testing and application of a few lbs of vulcum; IF the trailer is moved again...
there will be new "unsealed" gaps just from travel and the wiggles...
it ain't a oyster shell watch case folks!
cheers
2air'
all of the true things that i am about to tell you are shameless lies. l.b.johnson
Old 06-28-2008, 07:27 PM   #9
Shacksman
Shacksman's Avatar
Profile:  1967 22' Safari
1960 28' Ambassador
Avonton , Ontario
With those 2 hot air balloons you have, you could hook one to each end and have a unique gondola to ride to rallys.
Doug
WBCCI #3327 - VAC
73 Argosy
67 Safari
60 Ambassador Int.
Shacksman is offline   Reply With Quote
Old 06-28-2008, 07:34 PM   #10
rideair
Profile:
Reason for the test is to look for leaks that I may not know about. I understand there are many people who have used this method to finds leaks. You have a source of air coming into the trailer, spay the outside with a soap/water solutions and start looking for bubbles. I just wanted to make sure I did not use to much air volume/pressure.
Paul Waddell
Region 2 VAC Guy
Old 06-28-2008, 11:16 PM   #11
ROBERTSUNRUS
ROBERTSUNRUS's Avatar
Lakewood , California
Images: 18
[quote=rideair;582992]"Reason for the test is to look for leaks that I may not know about."
Hi, if you don't know there are any leaks why look? If it's not broken, don't fix it.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
2000 Navigator / Equal-i-zer / P-3
YAMAHA 2400 / AIR #12144
ROBERTSUNRUS is online now   Reply With Quote
Old 06-29-2008, 12:09 AM   #12
pauly g
Profile:  1960 22' Safari
Oceanside , California
Pressurizing an airstream sounds like crazy idea. The forces will grow to incredible levels with even 1 psi. A 24x36 window with 1 psi on it would be forced outward with a force of about 864 lbs! Fortunately, I think that there would be so many little leaks that it would be impossible to reach much pressure without a huge compressor. Maybe the shop vac idea would work, and be safe.
pauly g is offline   Reply With Quote
Old 07-02-2008, 03:59 PM   #13
easyride
naples , Florida
You could always go with some plumber`s smoke bombs,though you would have to air it out for a few weeks afterwards,cause they sure do stink.I wouldn`t do it and I have the bombs in my van.Dave
Old 07-02-2008, 04:22 PM   #14
markdoane
Images: 59
Ignorance is bliss?
I wish I'd known about the imaginary leaks that rotted my floor.
Under pressure ArtStream Tires 5 05-23-2006 06:25 AM
too much pressure? Chas Water Heaters, Filters & Pumps 23 04-28-2004 09:31 AM
tire pressure Land Yacht Deb Tires 1 01-18-2004 12:50 PM
No water pressure gmlcjb Fresh Water Systems 9 12-29-2003 04:09 AM
Low pressure / High pressure appliances Rick LP Gas, Piping, Tanks & Regulators 1 06-15-2002 06:29 PM
