Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Leaks - Weatherstrips, Gaskets, Caulks & Sealants
Old 07-07-2008, 01:15 PM   #15
rideair
Profile:
Markdoane,
That is what I'm trying to prevent. Many times you hear about the person with the rotted floor that had no idea they even have a leak.
In the end, I may just use all three Fantasic Vent sucking air into the trailer to do the test. I know if I have them all blowing out at the same time it will suck the door shut.
Paul Waddell
Region 2 VAC Guy
WDCU "Past Prez" (In the words of Richard Nixon "You won't have me to kick around anymore!")
rideair is offline   Reply With Quote
Old 07-07-2008, 04:44 PM   #16
Aerowood
Aerowood's Avatar
Profile:  1971 21' Globetrotter
Arvada , Colorado
I think that .5 psi is to much and you will create leaks. Thats alot of volume. Airstream construction methods will not support pressurization.
Under pressure ArtStream Tires 5 05-23-2006 06:25 AM
too much pressure? Chas Water Heaters, Filters & Pumps 23 04-28-2004 09:31 AM
tire pressure Land Yacht Deb Tires 1 01-18-2004 12:50 PM
No water pressure gmlcjb Fresh Water Systems 9 12-29-2003 04:09 AM
Low pressure / High pressure appliances Rick LP Gas, Piping, Tanks & Regulators 1 06-15-2002 06:29 PM
