Old 11-14-2009, 05:54 PM   #1
1961 16' Bambi
1967 17' Caravel
Tempe , Arizona
Images: 27
How Do I Replace Windows In '61 Bambi
I have just purchased a '61 Bambi that will need all the windows re-sealed and one glass replaced (if I don't break the rest taking them out).
I see it looks like I can order materials from Vintage Trailer Supply.
Is there anyplace or anyone that can tell me the process for the re-install?
HELP PLEASE!
Nancy in Arizona
Puggzilla is offline   Reply With Quote
Old 11-14-2009, 06:02 PM   #2
goransons's Avatar
1963 22' Safari
1955 26' Cruiser Overlander
Yakima Valley , Washington
Send a message via MSN to goransons
Nancy, welcome to the forums.. I think this one will do the trick:
Restoration Topics - Window Repairs
you'll also find they have a lot of other great little DIY articles in their restoration resources section (link at the top of the screen from the link here)
Scott & Megan
VAC LIBRARIAN
Restoring Wally Byam's 1955 26' European Caravan Trailer!
WBCCI 8671
1963 Safari from the 1963-64 Around the World Caravan
goransons is offline   Reply With Quote
Old 11-14-2009, 06:03 PM   #3
Vintage Alum. Enthusiast
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
Hi Nancy and welcome to the forums ~
I imagine your windows are very similar to mine. If you'll go look at your lower window frame that is riveted to the skin, there should be a number similar to HEHR 1009 4219. If this is the case, removing them is a fairly simple task. I can walk you through it once we determine your style of window.
Let's see some pictures of your new-to-you beauty. We all here love to see pictures.
Glad to see another vintage Airstream owner here in the Valley.
FF
4CU 2699 / AIR 10 / TAC AZ-1
I'm haunted by aluminum.
flyfshr is offline   Reply With Quote
Old 11-15-2009, 08:07 AM   #4
1961 16' Bambi
1967 17' Caravel
Tempe , Arizona
Images: 27
Thank you so much for the speedy reply. I'm glad I'm not alone out here. I will try to attach a few photos of my trailer. I appreciate any input you seasoned veterans can give. I don't even know how (or if) the water and sewer systems work. I have taken a leap of faith with this gal and I will take things one step at a time. Right now it is the windows.
You are welcome to come by and take a look in person anytime. I am in Tempe just off the 101.
Best regards,
Nancy
Old 11-15-2009, 08:08 AM   #5
1961 16' Bambi
1967 17' Caravel
Tempe , Arizona
Images: 27
Thank you very much. I am so excited to start working on this wonderful trailer. I appreciate all the help I can get. If you would like to come by and see her I am in Tempe.
Old 11-15-2009, 08:11 AM   #6
1961 16' Bambi
1967 17' Caravel
Tempe , Arizona
Images: 27
Thank you very much. I am getting wonderful information on the window replacement. I am definately going to call Vintage Trailer supply tomorrow and order up my supplies. Looks like a Thanksgiving project for sure. Please feel free to come by and see us if you are in Tempe.
Nancy
Old 11-15-2009, 08:25 AM   #7
1961 16' Bambi
1967 17' Caravel
Tempe , Arizona
Images: 27
1961 Bambi Photos and VIN#
Here are a few "before" shots.
I am wondering how to read the VIN number.
It is 161T117
It is an Ohio built unit.
Can you decipher it for me?
ID:	91032   Click image for larger version
ID:	91034   Click image for larger version
Old 11-15-2009, 08:43 AM   #8
silverleeper's Avatar
1967 22' Safari
1960 Caravel
Edmonds , Washington
Images: 8
Hi, Take a look here for the windows. Restoration Topics - Window Repairs
Take a look here for the trailer. 61Bambi
1 61(year) T(twin?) 117(production number)
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
silverleeper is offline   Reply With Quote
Old 11-15-2009, 08:50 AM   #9
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
What a beautiful little trailer. She looks to be in great shape. Here's a go on the VIN:
161T117 - 16 for 16 foot (making it a Bambi), 1 for '61 (model year), T for twin bed and 117 for the 117th Bambi made in Ohio
Did you get this trailer locally and if so, did you have to tow it far? How did it handle?
Maybe this week we can hook up. I'd like to see her in person. Shoot me a PM (private message) and we can connect.
FF
Old 11-15-2009, 08:55 AM   #10
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
When you get the replacement gaskets in hand, replacing the gaskets and window glass is easy. The glass is standard window glass, and is pretty inexpensive.
To remove, simply peel out the old gaskets, and the window should pretty much fall out. After you clean the gasket tracks, place the glass in the window, and apply some silicone slip-spray to the track. Cut the gasket to fit, with a 45 degree angle facing the center of the window, and work the gasket into the track using something reasonable thin and blunt. Apply aluminum colored Parrbond to the joints at the corners.
That's it.
HELP!! how to replace glass on 62 Bambi? vintagemike Leaks - Weatherstrips, Gaskets, Caulks & Sealants 2 08-09-2009 01:52 PM
do I really need to replace the windows? all of them?? Y2k_Knight Windows & Screens 6 05-03-2009 09:49 AM
replace gasket on wing windows - 75 argosy bamaargosy28 Windows & Screens 0 04-11-2009 02:51 PM
Replace/fix cruddy fixed windows? 26.982 amu Windows & Screens 3 01-01-2007 08:57 AM
Bambi II streetside windows yukionna 1964 Bambi II 2 04-14-2005 10:05 AM
