Old 09-22-2006, 04:27 PM   #1
Becky B.'s Avatar
1964 17' Bambi II
Schererville , Indiana
How do I fix this leak?
I have done everything I have been suggested to do by all the previous threads, and I still have water coming in my streetside storage locker. I have put a new gasket in, put new gaskets on the vents on the roof & recaulked everything up there, recaulked the door itself, recaulked the rub rail, and tried to get the door to shut more tightly. That seems to be my problem, I think. When looking from the inside (under the bed) out, I can see the light of day. Does anyone have any more suggestions on how I can get the door to shut more tightly? The floor is rotting more & more, since it seems to rain twice a week here!
Name:	street side storage locker outside (gap).gif
ID:	26211   Click image for larger version
Name:	street side storage locker gap.gif
Name:	Street side storage locker inside (gap).gif
ID:	26213   Click image for larger version
Name:	street side storage locker floor rot.gif
Becky
1964 Bambi II
1988 Avion 32S
Becky B. is offline   Reply With Quote
Old 09-22-2006, 04:40 PM   #2
garthbf's Avatar
1975 31' Sovereign
1960 26' Overlander
Mount Vernon , Washington
from the photos it looks like the gap is at the top so I am thinking that the new gasket is not right. Are you using this kind?
http://www.inlandrv.com/parts/45308-gasketentr.jpg
If you are using this kind then it is incorrect...
http://www.inlandrv.com/parts/005s-gasket.jpg
thanks to inlandrv for having these photo on their website.
garthbf is offline   Reply With Quote
Old 09-22-2006, 05:05 PM   #3
Becky B.'s Avatar
1964 17' Bambi II
I did use that gasket. I ordered it from the guy holding it! Here's a picture of the install.
Name:	Street side storage locker gasket.gif
Becky
1964 Bambi II
1988 Avion 32S
Old 09-22-2006, 05:30 PM   #4
Jim Clark's Avatar
2012 28' International
New Orleans , Louisiana
The good part is you know where the leak is at. Have you checked to see if the door is warped or the hinge is out of aligment. It appears you have an aligment problem and not a gasket problem.
Jim N5TJZ Air# 174
2012 International Serenity 28
2005 Safari 25 SS Traded
1968 Globetrotter Sold
2011 F150 Ecoboost
Jim Clark is offline   Reply With Quote
Old 09-22-2006, 06:06 PM   #5
Becky B.'s Avatar
1964 17' Bambi II
Well, I just went outside & bent the hinge out a bit. I'm afraid of breaking it! Looks a little closer. We're going to have rain again tonight, so I'll find out tomorrow if it made any difference.
Becky
1964 Bambi II
1988 Avion 32S
Old 09-22-2006, 06:47 PM   #6
Jim Clark's Avatar
I also wonder if your gasket is on backwards. I will look at mine in the morning and see which way it is facing. I have a 2005 so it may not be the same.
Jim N5TJZ Air# 174
2011 F150 Ecoboost
Old 09-22-2006, 07:01 PM   #7
Becky B.'s Avatar
1964 17' Bambi II
I'm pretty sure I put it on in the right direction--I looked at the ones I hadn't done yet. I think the main problem may be the gap at the top. You must be right about the hinge or the door being warped. I took a screwdriver & tried to bend the hinge out a bit so the bottom comes out more. Before that, I bent the lock latch to try to get it closer. If it still leaks, I'll have to try to bend the hinge a little further. It makes me a bit nervous, though.
Becky
1964 Bambi II
1988 Avion 32S
Old 09-22-2006, 07:11 PM   #8
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
I think I would glue some non-porous gasket material to the lip of the door frame to solve the problem. The door is misaligned but you might break something before you get it right. It may not be the most elegant solution but I would vote for utility over looks.
Old 09-22-2006, 08:27 PM   #9
PizzaChop's Avatar
1973 31' Sovereign
Danielsville , Georgia
Images: 202
I'm trying to remember but it seems that I took the latch assembly apart or something to make mine tighter on the Overlander. It was almost two years ago so I'm not sure exactly what I did. There may have been some bending involved as well. I have the other type of gaskets on mine. (Which I don't understand, as the '72s and '73s look pretty much like the '76.)
Ron Kaes
Psalm 112
www.paparonnis.com
PizzaChop is offline   Reply With Quote
Old 09-23-2006, 05:48 AM   #10
Happycampers's Avatar
1979 30' Argosy
Havelock , where we park it
Close the door spray some soapy water around the outside of the door, have someone go inside, (if you have an air compressor) blow air around the inside of the door and watch for bubbles. That will tell you exactly where the leak is top bottom or sides. Then close the door again with out the lock latched and push very hard closing the door and hold it and repeat the above process. If the leak is around the top of the door it might just need adjusting. other wise you will at least know where the leak is. If you find the leak and there is no adjustment and it is almost sealed you can put some transmission fluid on the gasket, that will make the gasket swell, that will work but it will also shorten the life of the gasket.
Marvin & Annie
Niki (fur baby)
1979 Argosy 30 (Costalotta)
WBCCI 10103
"Happiness is a warm Puppy" Charles Schulz
Happycampers is offline   Reply With Quote
Old 09-28-2006, 06:16 PM   #11
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Becky,
You seem to have the right gasket for your year according to Inland and the links that Garthbf was good enough to supply. You might think about going with the prior year gasket with your situation. This one that Garthbf provided
We just did the same door on our 71 and had to play with it to see which way it should go on. Decided the idea would be to stand it up as you see in the link with the tallest part facing inward - so glue it out on the edge of the door - not to the door lip. The idea being that the tall edge will contact the inside edge - any water that wicks in will drop into the "U" channel of the gasket and run to the bottom. Your seam should be on the bottom obviously.
In the meantime you may (if your waiting for new gasket) want to seal the door edge with blue painters tape to stop the leak (no sticky stuff left over removing it). Another thought is to tape plastic - using aluminum tape - to form a sort of bucket under the leak inside to prevent further damage. May want to blow dry the wood first to prevent mold from forming under the plastic.
I have two orders of this type gasket and likely have a spare piece long enough to try - can mail it to you early next week if you want to try it.
Good luck with your leak - nice shine on that baby.....!!
Old 09-28-2006, 07:16 PM   #12
rebel beck's Avatar
1975 31' Sovereign
Oxford , Mississippi
Images: 35
Becky,
As mentioned before it looks like an alignment problem, we have a 75 and the same door always falls off when I'm putting something back there. If I don't put it back just so (hold my mouth right) i have the gap just like yours.
By the way your trailer looks great with the polish job, I hope to start on mine soon.
Becky
75 Sovereign (Peppy)
03 Chevy HD (lil Peppy)
Air# 9552
rebel beck is offline   Reply With Quote
Old 09-28-2006, 07:44 PM   #13
steelbird312's Avatar
1956 22' Safari
2000 39' Land Yacht XL Diesel w/slide
Crossville , Tennessee
Images: 11
Becky,
I agree with Ganglin partially, especially about gluing the seal to the edge of the lip instead of back towards the 'L'. Also, it is very possible that the door FRAME is what is bent instead of the door! I have seen them where they were, possibly by being bent sloppily by the press when it was made. Getting at the inside, (take the matress off and fold up the bed base) and then make sure the frame is equal distant from the door all around, and if not, it's time for a little peck, peck, peck work on the door frame until it is uniform all around, and close to the frame itself.
Good luck
steelbird312
2000 390 Landyacht XL
1989 29' Excella
WBCCI #6673 jerry Hodge
Have no intention of arriving at the grave safely, but rather to skid in sideways, chocolate in one hand,throttle in the other, totally worn out and screaming
"WOO HOO, WHAT A RIDE!"
steelbird312 is offline   Reply With Quote
Old 09-28-2006, 08:11 PM   #14
Becky B.'s Avatar
1964 17' Bambi II
It actually hasn't rained since I posted the last time. I've pushed the door top really hard & tried to adjust the hinge so far. I looks quite a bit closer. I'm off work tomorrow & might just try a hose to see if it's tight. Thanks for the advise! I'll mess with the frame if need be too. I just put the gasket on, so I hate to rip it off & put something else on that's not like the original, but if all else fails.....I'll have to take Ganglin up on his offer to try his kind of gasket! Thanks & I'll let you know what happens.
Becky
1964 Bambi II
1988 Avion 32S
Water leak panoramic windows Andy Fay Windows & Screens 16 01-05-2007 08:33 AM
Rainwater leak James Schmidt Leaks - Weatherstrips, Gaskets, Caulks & Sealants 8 09-11-2002 06:28 AM
Globetrotter 1963 - Kitchen Sink Drain Leak Under the Floor Uncle_Phil Plumbing - Systems & Fixtures 3 08-09-2002 06:59 PM
Leak in Water System Rich Palmieri Fresh Water Systems 6 06-27-2002 06:17 AM
Propane valve leak Dbraw LP Gas, Piping, Tanks & Regulators 3 06-14-2002 06:12 PM
