Old 04-23-2007, 10:59 AM   #1
Surprise , Arizona
How can I clean up Vulkem?
I want to use Vulkem to reseal the freshwater fill-assembly to my trailer's aluminum skin, but I'm concerned about the mess it'll make.
How can I clean up when I'm done?
What's a good solvent for Vulkem?
Thanks!
TitusLivy is offline   Reply With Quote
Old 04-23-2007, 11:21 AM   #2
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
you should probably use something called "par-bond" for that, rather than vulkem. Vulkem is ok for larger gaps. The really small ones can be more neatly filled w/ par-bond, or "acryl-r". (the factory used to use parbond; now they use acryl-r). They're both thin and runny, and tend to wick into these really small gaps. (Vulkem or sixaflex, which are both more heavy "caulking" are best for the larger gaps, like roof hatches and windows).
you can get them from the airstream store, or vintage trailer supply.
with either, if you mask the area carefully, you won't need to worry about cleanup. I've gotten so I can use par-bond without masking...its possible to lay down a clean, narrow bead without making a mess. use masking tape the first few times, leaving about a 1/8th inch gap along the joint, just to get the hang of it...you'll see what I mean.
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 04-23-2007, 11:21 AM   #3
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Maybe this will help you.
http://www.piedmontplastics.com/stat...%20Sealant.pdf
Old 04-23-2007, 11:58 AM   #4
Surprise , Arizona
Thanks for this info, folks! Very helpful!
Titus
Old 04-23-2007, 01:06 PM   #5
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Best clean up for Vulkem is Mineral Spirits or Paint Thinner.
Aaron
WBCCI #XXXX AIR #2495
Old 04-27-2007, 01:40 PM   #6
Surprise , Arizona
Per Ganglin's post, Vulkem's manufacturer recommends cleanup with Toluene or Xylene, neither of which is readily available in the typical home improvement store. But as other poster's noted, these products are often included in paint thinners and related items. I found a "paintbrush cleaner", for example, that contained both, and it did a great job of removing fresh Vulkem without damaging my trailer's aluminum skin.
Thanks again to everyone who pointed me in the right direction on this issue!
Titus
Old 04-27-2007, 02:13 PM   #7
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
I've bought xylene (lots of it) at Home Depot.
its on the shelf w/ all the other paint/solvents.
Air:291
Wbcci: 3752
'73 Safari 23'
Old 04-27-2007, 02:55 PM   #8
balrgn's Avatar
1974 27' Overlander
1954 26' Romany Cruiser
1960 26' Overlander
Rockingham County , New Hampshire
Images: 74
Send a message via AIM to balrgn Send a message via Yahoo to balrgn
Aaron
I agree, just used some last night. Cleaned up great.
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
'54 Cruiser (Bogart)
'60 Overlander (Hoagy)
WBCCI 1754 - AIR # 6281
www.balrgn.com
balrgn is offline   Reply With Quote
Old 04-27-2007, 03:02 PM   #9
Excella CM's Avatar
1978 31' Excella 500
Venice , California
The less exotic the solvent, the better-for you. Paint thinner works fine when the vulkem's fresh. When it's dry, use dynamite.
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 04-27-2007, 03:16 PM   #10
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
Originally Posted by Excella CM
... When it's dry, use dynamite.
ya. been there.
actually, I found (after trying every solvent I could find...xylene working the best...but still an arduous task) that a heat gun worked really well. softened it right up, and let me srape it off with a plastic putty knife. The heat gun I used was meant for de-soldering printed circuit boards, so it has a very small nozzle...just about perfect for a bead of vulkem.
Air:291
Wbcci: 3752
'73 Safari 23'
Old 04-27-2007, 04:02 PM   #11
balrgn's Avatar
1974 27' Overlander
1960 26' Overlander
Images: 74
Originally Posted by Chuck
ya. been there.
Same here, I soften the old stuff with a heat gun as well. Good technique!
www.balrgn.com
application temperature for vulkem bhsl8 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 10 02-25-2007 09:35 AM
Vulken and Polish or Polish then Vulkem? rookie Cleaning, Stripping & Polishing 5 07-23-2002 07:15 AM
Vulkem sealant Stougard Leaks - Weatherstrips, Gaskets, Caulks & Sealants 5 07-01-2002 12:25 PM
Removing Vulkem JrnymnJay Leaks - Weatherstrips, Gaskets, Caulks & Sealants 3 05-03-2002 11:49 PM
inside light lens' how to remove to clean Paul Daugherty Mechanics Corner - Engines, Transmission & More... 12 04-25-2002 10:51 PM
