Old 04-17-2016, 05:07 PM   #1
DDickey's Avatar
1957 22' Custom
Lago Vista , Texas
Holy Moly, she leaks like a sieve
I'm starting to do the fully monty on a 1975 13 panel and I have all of the interior skins off. We had a good rain here today: 17 leaks and counting. It seems like every seam has a wet spot or a drip. Can these things really be sealed up from the inside?
DDickey is offline   Reply With Quote
Old 04-17-2016, 07:09 PM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Welcome to the real world of vintage trailers(any brand). They all leak at least some of the time. Just like real VW bugs and Harleys leak oil and boats leak water.
MICHAEL
Old 04-17-2016, 07:14 PM   #3
1972 27' Overlander
Denver , North Carolina
Probably because there are no 1973 13 panel Airstreams. You must mean 1953?
Lucky Dave, Denver NC
mccrosti is offline   Reply With Quote
Old 04-18-2016, 06:31 AM   #4
Long Island , New York
1957 in his ID on the left.
Welcome to the forum DDickey, and Good Luck . . . !
I have no expertise about this, but am interested in knowing more. Some kind of penetrating epoxy for the seams? Drill out rivets at overlapping seams and caulk? With what?
Let the Summer Games begin!
Peter
OTRA15 is online now   Reply With Quote
Old 04-18-2016, 08:00 AM   #5
DDickey's Avatar
1957 22' Custom
Lago Vista , Texas
Dyslexia
Whoops, my showing is dyslexia itself, I meant 1957
Old 04-18-2016, 08:49 AM   #6
rugjenkins's Avatar
1975 Argosy 28
Springville , Alabama
I have found most leaks are from loose rivets and windows. I wait until a good rain and mark them with a sharpie. Then replace and reseal.
Matt
rugjenkins is offline   Reply With Quote
Old 04-18-2016, 10:09 AM   #7
MarkR's Avatar
1951 21' Flying Cloud
1960 24' Tradewind
Folsom , California
Images: 12
the most "painless" and "realistic" solution is to move to:
https://www.currentresults.com/Weath...cipitation.php
Or - do like I do and keep it under a canopy at all times - it's kind of expensive paying for the 2 guys w/ the "Wide Load" Sign on their cars, that must drive in front and in back of us everywhere we go . . .
Maybe it's a combination of finding loose leaky rivets and replacing them and cleaning all the inside seams w/ Lacquer Thinner and then running a bead of Polyurethane Sealant like Trempro or Sika on the inside and then using your thumb to "push" it into the seams . . . short of taking the thing completely apart and putting it back together.
Aluminumbskull with Led Balloon in Drag
Birch Plywood and Aluminum go together like
Peanut Butter and Chocolate
MarkR is offline   Reply With Quote
Old 04-18-2016, 10:24 AM   #8
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
I drilled the rivets out of every seam on the trailer, cleaned, injected sealant, and then re-installed the rivets. It was a lot of work but it doesn't leak anymore.
Old 04-18-2016, 10:42 AM   #9
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
OUTSIDE IS BETTER. Lazy way - if you have access to two box trucks, park one on each side of the Airstream and make 2 X 10's into a laydown ramp over the roof. It's also possible to rent a few sections of scaffolding quite inexpensively, OR just use a nice long ladder with a brace (2x4 covered in carpet about 2.5 feet long - to keep the rails from marking up the side of the Airstream. I find the reach across too far for my short self.
Captain Tolley's Creeping Crack Cure on every single rivet. Mark the ones where the liquid disappears inside, and re-treat them a day later. 99% won't leak the second time. On the seams, clean out all of the old sealant, then use Trempro or Sikaflex to reseal. For a NEAT seam, use two parallel strips of masking tape or painters tape, one on each side of the seam. Apply the caulk, finger smooth, wait briefly for the caulk to START setting, then remove the tape.
Old 04-18-2016, 11:02 AM   #10
1972 27' Overlander
1957 - very nice! Pull out the interior skins and slather Vulkem all over the seams from the inside. Also check your window seals if they're rotted they will leak
Old 04-18-2016, 01:38 PM   #11
1968 22' Safari
Tulsa , Oklahoma
Finding/Fixing Leaks with the skin on?
How do you do that with the interior skins on? Or is that just when you remove them and, if that's the case, how often do you do that?
Which begs a question: Has anyone ever devised a way to identify, locate and repair shell leaks with the relevant interior skin on?
splyb is offline   Reply With Quote
Old 04-18-2016, 02:50 PM   #12
rugjenkins's Avatar
1975 Argosy 28
DDickey posted he had the interior skins off doing a fully Monty. I still have my interior off until I spray soon.
With interior skins on- captain tolley is good and reseal exterior seams an windows
Pressure testing is the way many check when all is together or apart
Matt
Old 04-18-2016, 09:00 PM   #13
DDickey's Avatar
1957 22' Custom
Lago Vista , Texas
Captain Tolleys
So should Captain Tolleys be used from the outside, or the inside, or both, or does it matter? I just ordered some from West Marine...
Old 04-18-2016, 11:51 PM   #14
"Space A" S/O Registry 11
2006 34' Classic S/O
Fort Worth , Texas
If you want to treat the wall/skin that is not visible against corrosion. Get some Zinc Chromate from an aircraft supplier. That is the old standby method used in aluminum aircraft manufacturing. Be sure and use a respirator, or you will get zinc poisoning in the lungs. Don't ask how I know.
guskmg
Holy Moly, the furnace works! alistheman Furnaces, Heaters, Fireplaces & Air Conditioning 8 02-03-2014 12:33 PM
Holy-Moly the heat pump is noisy Bbelk Furnaces, Heaters, Fireplaces & Air Conditioning 10 01-18-2014 02:09 PM
Holy Moly, our new window fell out!! eubank Windows & Screens 24 05-23-2007 05:19 PM
holy, moly! codybear Off Topic Forum 28 11-09-2006 11:35 AM
HOLY MOLY! What are you paying for 59toaster Ribs, Skins & Rivets 35 11-05-2003 09:30 PM
