Old 04-17-2016, 04:07 PM   #1
Registered User
DDickey's Avatar
1957 22' Custom
Lago Vista , Texas
Holy Moly, she leaks like a sieve
I'm starting to do the fully monty on a 1975 13 panel and I have all of the interior skins off. We had a good rain here today: 17 leaks and counting. It seems like every seam has a wet spot or a drip. Can these things really be sealed up from the inside?
DDickey is offline   Reply With Quote
Old 04-17-2016, 06:09 PM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Welcome to the real world of vintage trailers(any brand). They all leak at least some of the time. Just like real VW bugs and Harleys leak oil and boats leak water.
MICHAEL
Old 04-17-2016, 06:14 PM   #3
1972 27' Overlander
Denver , North Carolina
Probably because there are no 1973 13 panel Airstreams. You must mean 1953?
Lucky Dave, Denver NC
mccrosti is offline   Reply With Quote
Old 04-18-2016, 05:31 AM   #4
Sag Harbor , New York
1957 in his ID on the left.
Welcome to the forum DDickey, and Good Luck . . . !
I have no expertise about this, but am interested in knowing more. Some kind of penetrating epoxy for the seams? Drill out rivets at overlapping seams and caulk? With what?
Let the Summer Games begin!
Peter
Old 04-18-2016, 07:00 AM   #5
Registered User
DDickey's Avatar
1957 22' Custom
Lago Vista , Texas
Dyslexia
Whoops, my showing is dyslexia itself, I meant 1957
Old 04-18-2016, 07:49 AM   #6
rugjenkins's Avatar
1975 Argosy 28
Springville , Alabama
I have found most leaks are from loose rivets and windows. I wait until a good rain and mark them with a sharpie. Then replace and reseal.
Matt
rugjenkins is offline   Reply With Quote
Old 04-18-2016, 09:09 AM   #7
MarkR's Avatar
1951 21' Flying Cloud
1960 24' Tradewind
Folsom , California
Images: 12
the most "painless" and "realistic" solution is to move to:
https://www.currentresults.com/Weath...cipitation.php
Or - do like I do and keep it under a canopy at all times - it's kind of expensive paying for the 2 guys w/ the "Wide Load" Sign on their cars, that must drive in front and in back of us everywhere we go . . .
Maybe it's a combination of finding loose leaky rivets and replacing them and cleaning all the inside seams w/ Lacquer Thinner and then running a bead of Polyurethane Sealant like Trempro or Sika on the inside and then using your thumb to "push" it into the seams . . . short of taking the thing completely apart and putting it back together.
Aluminumbskull with Led Balloon in Drag
Birch Plywood and Aluminum go together like
Peanut Butter and Chocolate
MarkR is offline   Reply With Quote
Old 04-18-2016, 09:24 AM   #8
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
I drilled the rivets out of every seam on the trailer, cleaned, injected sealant, and then re-installed the rivets. It was a lot of work but it doesn't leak anymore.
Old 04-18-2016, 09:42 AM   #9
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
OUTSIDE IS BETTER. Lazy way - if you have access to two box trucks, park one on each side of the Airstream and make 2 X 10's into a laydown ramp over the roof. It's also possible to rent a few sections of scaffolding quite inexpensively, OR just use a nice long ladder with a brace (2x4 covered in carpet about 2.5 feet long - to keep the rails from marking up the side of the Airstream. I find the reach across too far for my short self.
Captain Tolley's Creeping Crack Cure on every single rivet. Mark the ones where the liquid disappears inside, and re-treat them a day later. 99% won't leak the second time. On the seams, clean out all of the old sealant, then use Trempro or Sikaflex to reseal. For a NEAT seam, use two parallel strips of masking tape or painters tape, one on each side of the seam. Apply the caulk, finger smooth, wait briefly for the caulk to START setting, then remove the tape.
Old 04-18-2016, 10:02 AM   #10
1972 27' Overlander
1957 - very nice! Pull out the interior skins and slather Vulkem all over the seams from the inside. Also check your window seals if they're rotted they will leak
Old 04-18-2016, 12:38 PM   #11
1968 22' Safari
Tulsa , Oklahoma
Finding/Fixing Leaks with the skin on?
How do you do that with the interior skins on? Or is that just when you remove them and, if that's the case, how often do you do that?
Which begs a question: Has anyone ever devised a way to identify, locate and repair shell leaks with the relevant interior skin on?
splyb is offline   Reply With Quote
Old 04-18-2016, 01:50 PM   #12
rugjenkins's Avatar
1975 Argosy 28
DDickey posted he had the interior skins off doing a fully Monty. I still have my interior off until I spray soon.
With interior skins on- captain tolley is good and reseal exterior seams an windows
Pressure testing is the way many check when all is together or apart
Matt
Old 04-18-2016, 08:00 PM   #13
Registered User
DDickey's Avatar
1957 22' Custom
Lago Vista , Texas
Captain Tolleys
So should Captain Tolleys be used from the outside, or the inside, or both, or does it matter? I just ordered some from West Marine...
Old 04-18-2016, 10:51 PM   #14
:SPACE A" S/O 11 Air19745
guskmg's Avatar
2006 34' Classic S/O
Fort Worth , Texas
If you want to treat the wall/skin that is not visible against corrosion. Get some Zinc Chromate from an aircraft supplier. That is the old standby method used in aluminum aircraft manufacturing. Be sure and use a respirator, or you will get zinc poisoning in the lungs. Don't ask how I know.
guskmg
Old 04-19-2016, 08:55 AM   #15
rugjenkins's Avatar
1975 Argosy 28
Captain tolley on the exterior. Replacing the rivets is just as easy too.
Matt
Old 04-19-2016, 09:12 AM   #16
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
Also be aware that water can travel a long ways from the actual leak site before it finds it's way into the trailer. That's why treating everything above and to either side of the leak is important. Our windows were the biggest leakers when we got our trailer, but we had a couple upper skin ones too. We sealed outside and inside, and have had only one since (this spring). I think we've got that one stopped now too. We used Captain Tollys, sikaflex, and Vulkem.
Kay
Minno is online now   Reply With Quote
Old 06-13-2016, 09:03 PM   #17
asv2's Avatar
2008 25' Safari
Jacksonville , Florida
Great tips - I'm getting ready to reseal for first time, and am learning. We used Sikaflex 715 to install a new Maxim skylight , and are trying to determine the best sealant for the rest of everything. How much Capt Tolleys would you recommend? Seems it would go fast. We used acetone to clean when removing the old caulk on the skylight, so I guess that would be good for the rest(?) Do you recommend the Sikaflex 221 (since it's grey) and which Trempro - the 635 or 636? And are these also good for around tail lights, bumper, eyebrows above windows, or do you use something else for any of those areas?
asv2 is offline   Reply With Quote
Old 06-19-2016, 08:51 PM   #18
carl2591's Avatar
2005 31' Classic
Garner, , North Carolina
I also used Sikaflex but the RTV 7000 series when installing the maxim skylight. decided not to use any screws in side of curb as that is a good adhesive and sealer.
used,or are using capt tolleys as well. I just stuck the tip on the gaps and let it flow moving it like a caulking gun. It would run down the gap around windows soaking in cracks as needed. I would wipe the excess off best as i could but some slipped by. the places it sucked up the most i would make a mental note and go back to that one after a while to let it suck up more.
when i replace the skylight i would use a sharp wood chisel and remove the curb edge old caulking and resealed with dicor. i ran a nice bead on top of curb with the rtv7000 and put new skylight on getting it centered and let sit.
I went inside and wiped the excess silicon off the inside of the curb letting it sit overnight. the next day I tried to push it off and after using some good muscle power decided it was good without screws.
took a 200 plus mile trip this weekend and no leaks, no flyoff etc.. plus they look good for sure.
Carl, Raleigh NC
2-24-16 got a 2005 Classic 31D 460 watts solar, lithium 230 AH, 16" LT's, pulled by:
2003 F-250 SD, CC, 7.3L PowerStroke
WBCCI#1691, Piedmont Airstream Club, Unit #161, Region #3
carl2591 is offline   Reply With Quote
Old 06-20-2016, 09:05 PM   #19
asv2's Avatar
2008 25' Safari
You are bold going without the screws on side curb. That must be a good sealant. Glad nothing flew off or leaked! For Capt Tolleys, did you use 2 oz. or 8 oz.?
Old 06-21-2016, 07:47 PM   #20
carl2591's Avatar
2005 31' Classic
the silflex rtv7500 not 7000 is a good sealant/adhesive. I use it a lot so I am aware of it strength to hold stuff. Now if i was to get a pry bar and some wood i could pop it off but short of that ,, it on there till its need to come off which will not in my lifetime.
i get a 8 oz bottle of capt tolleys and man that stuff is the deal. went out today to finish up scraping off sealant on the top rail between the white and non white metal. got a nice bead of dicor on it and good to go.
also did some CTing around the top windows and they did suck some stuff in.
it is good stuff to use around windows, doors etc on the exterior if the OEM stuff is in decent shape. If not you need to scrape and redo.
Carl, Raleigh NC
Holy Moly, the furnace works! alistheman Furnaces, Heaters, Fireplaces & Air Conditioning 8 02-03-2014 11:33 AM
Holy-Moly the heat pump is noisy Bbelk Furnaces, Heaters, Fireplaces & Air Conditioning 10 01-18-2014 01:09 PM
Holy Moly, our new window fell out!! eubank Windows & Screens 24 05-23-2007 04:19 PM
holy, moly! codybear Off Topic Forum 28 11-09-2006 10:35 AM
HOLY MOLY! What are you paying for 59toaster Ribs, Skins & Rivets 35 11-05-2003 08:30 PM
