Old 06-30-2016, 09:47 PM   #29
asv2's Avatar
2008 25' Safari
Jacksonville , Florida
Thank y'all, I appreciate all your tips. I decided to go with the Sikaflex 221 along with the CT and Acryl-R. Now to order everything and get started!
asv2 is offline   Reply With Quote
Old 07-07-2016, 08:28 AM   #30
Alluminati's Avatar
St. Louis , Missouri
Any help here for a newbie?
Just a quick question: I have a couple roof leaks that need addressing. Should I seal the inside skin too? Sounds like everyone here says sealing the inside is SOP.
Im afraid that if the inside skin is water tight, Ill never know when the outside skin leaks. Im concerned I could be taking on water for years before I ever see any evidence. As it is now, Im wondering how far the water traveled between the skins before it finally found its way inside.
Alluminati is offline   Reply With Quote
Old 07-07-2016, 03:01 PM   #31
rugjenkins's Avatar
1975 Argosy 28
Springville , Alabama
The inside skin we are referring to are the interior exterior skins.
Matt
rugjenkins is offline   Reply With Quote
Old 07-08-2016, 05:32 PM   #32
Alluminati's Avatar
Ah! Thanks.
I'm new here, and haven't learned all the lingo yet. Pertinent details still get past me. With that knowledge, rereading the thread, it's clear now. So I'm on my way to HD to pick up some Sikaflex for the exterior of the exterior roof
Fortunately my rig was kept in covered storage when not on the road. When the A/C was replaced a couple years ago the new unit has a slightly smaller foot print. There's a gap on the seam where it runs under the A/C unit that is now uncovered.
The Morgans
1989 Avion 34VB, "QE3"
2008 Toyota Sequoia 5.7L "Tug"
(Is there no respect for an 8-ton GCVWR truck? *sniff* )
Old 07-16-2016, 09:13 PM   #33
rugjenkins's Avatar
1975 Argosy 28
Make sure you get the correct sikaflex. You need 221 sikaflex for just about everything. I used 715 sikaflex on the roof- it's semi self leveling. I believe the sikaflex at HD is for concrete. You can order the right stuff online😄 Make sure you get some painters tape to go around where you need it. This stuff is not that forgiving. Also get some minerial spirits for clean up.
Matt
Holy Moly, the furnace works! alistheman Furnaces, Heaters, Fireplaces & Air Conditioning 8 02-03-2014 12:33 PM
Holy-Moly the heat pump is noisy Bbelk Furnaces, Heaters, Fireplaces & Air Conditioning 10 01-18-2014 02:09 PM
Holy Moly, our new window fell out!! eubank Windows & Screens 24 05-23-2007 05:19 PM
holy, moly! codybear Off Topic Forum 28 11-09-2006 11:35 AM
HOLY MOLY! What are you paying for 59toaster Ribs, Skins & Rivets 35 11-05-2003 09:30 PM
