Old 06-10-2012, 09:08 PM   #1
1966 26' Overlander
Conover , Ohio
hinge leak
I have a leak at the door hinge. There is a small gap (arrow) between the hinge and the body for some reason. I have the inside skin pulled back enough that I can actually watch the water flow in, which then runs down the rib to the floor. I see no reason to remove the hinge because it seems very tight. Is there a sealer recommended for this type of leak? I have vulkem, but I was thinking something thinner that would flow into the gap.
Thanks, TomE
project66 is offline   Reply With Quote
Old 06-10-2012, 09:18 PM   #2
Thanks, TomE
Parr-Bond will work fine.
That gap was designed to accept the sheetmetal seam, which was not always placed in the same spot.
But since you have Vulkem, seal the leak from the inside.
Old 06-10-2012, 09:26 PM   #3
bilby05
bilby05's Avatar
1962 24' Tradewind
1962 24' Tradewind
Canyon , Texas
Thanks, TomE
I have used Paarbond, and it seems to work. Just remember it is messy and I would suggest using blue masking tape to reduce the need for clean up. I have a small plex window that I sealed with it and did not pretape. Can not get the stuff off.
Cheers bill b.
1962 Airstream Tradewind
2001 Ford 7.3 Diesel
bilby05 is offline   Reply With Quote
Old 06-10-2012, 09:50 PM   #4
Shacksman's Avatar
1960 28' Ambassador
1998 25' Safari
Avonton , Ontario
I had the same leak on my 67. I used this Capt. Tolley's Creeping Crack Cure also put it on the hinge rivets, they were leaking also.
Doug & Terry
VAC - TAC ON-1
60 Ambassador Int.
98 Safari
1950 Spartan
1966 Globetrotter
Shacksman is offline   Reply With Quote
Old 06-11-2012, 07:36 AM   #5
Shacksman's Avatar
1960 28' Ambassador
1998 25' Safari
Avonton , Ontario
Capt. Tolley's is available at West Marine stores.
Doug & Terry
VAC - TAC ON-1
60 Ambassador Int.
98 Safari
1950 Spartan
1966 Globetrotter
Old 06-11-2012, 08:01 AM   #6
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
[QUOTE=Shacksman;1159457]Capt. Tolley's Creeping Crack Cure/QUOTE]
That sounds like a cure for plumber's butt.
