Old 04-17-2003, 08:13 AM   #1
mike4038's Avatar
Unhappy Help stop the Leaks
I have 3 of these vents, all in bad shape.
2 are in the bath area 1 over the kitchen vent.
All three are on the curve of the roof.
Which vents should I order , and should they have covers over the tops?
Thanks Mike
Name:	roof vent (small).jpg
mike4038 is offline   Reply With Quote
Old 04-17-2003, 08:37 AM   #2
pap
Dirty picture
Hey Mike that's one dingy looking roof But when I visited your photo page your Airstream is shining like a mirror and lookin like a million bucks! Gotta be one of four things;
*two different trailers.
*roof photo was a before and photo page pix an after.
*your neighborhood had a bad acid rain storm.
*you're afraid of heights.
Are you in the Klein area?
Have any room for an exclusive Airstream storage lot?
Could call it the Airstream Ranch.
Hopefully Inland Andy will clarify your vent question. but I have read much about a rubber gasket under the pipe cap/cover you photoed needing replacement every 4-6 years and being the biggest source of unexplainable leaks.
Thats a good question about caps for the vent stax. I guess rain that enters the stack must end up in the holding tank eventually???
I think the leak problem is from water that enters around (but outside) the actual vent pipe, through the exit hole in the alum roof. The water then travels to anybody's guess where and finds its own exit where it is not welcome.
pap is offline   Reply With Quote
Old 04-17-2003, 09:30 AM   #3
mike4038's Avatar
Airstream Ranch
Pap,
I am in the Hobby Airport area on about 2 acres
on sims bayou. In the photos the airstream is parked
about 20 feet above the bayou. During the last flood that
area was about 2 feet underwater! Don't think you would
want to keep your airstream hear unless it had pontoons!
Mike
Old 04-17-2003, 10:21 AM   #4
MIKE4038.
Replacement sewer vent pipe covers is not a biggie.
Use the new style "polished sewer vent pipe covers" that are on current models. They have been used for over 30 years.
Pricey, but very functional.
We always have them on sale on our web site.
inlandrv.com
airstreamparts.com
airstreamcandy.com
« Parr Bond | Top | Caulking »
Water Leaks and Condensation-34' LTD lmcatee Leaks - Weatherstrips, Gaskets, Caulks & Sealants 3 04-04-2004 04:16 PM
Leaks Bob Ward Leaks - Weatherstrips, Gaskets, Caulks & Sealants 4 12-10-2003 06:23 PM
Can you suggest a good place to stop? joshua32064 On The Road... 4 12-07-2003 07:25 AM
Help with Leaks danesh Leaks - Weatherstrips, Gaskets, Caulks & Sealants 10 11-18-2003 09:58 AM
leaks Larry Leonard Leaks - Weatherstrips, Gaskets, Caulks & Sealants 1 11-03-2003 03:09 PM
