Old 05-15-2011, 07:13 AM   #1
McDonalds's Avatar
Bowdoinham , Maine
HELP!! Leaks in back
Okay, I've just about had it. My trunk leaks (1971 Overlander) on the right side and I can not find the leak. I've sealed just about everything. EXCEPT: the back running lights, the Airstream letters and the license plate light. After a rain there is always water in the 'c' channel of the door on the right, and water on the rotting wood on the right. HELP!!!
McDonalds is offline   Reply With Quote
Old 05-15-2011, 07:24 AM   #2
soldiermedic's Avatar
Florissant , USA
How does your vent pipe gasket look up top? That could be a cause. Also consider the roof vent, or rear access hatch if it has one.
Steve
Streaming Soldiers Blog
soldiermedic is offline   Reply With Quote
Old 05-15-2011, 07:42 AM   #3
kevin242's Avatar
1977 25' Tradewind
Waskesiu Lake , Saskatchewan
I have not done it, but I know some people have sealed up every window, door, vent and hatch and then opened a small window, sealed it with plastic allowing a hole in the plastic for a high air volume leaf blower nozzle or reversed shop vac nozzle and then pressurized the inside of the trailer. While the trailer is under pressure, they slop soapy water around possible leak locations and look for bubbles.
Worth a try?
Every home needs a dog, and every dog needs a home.
1977 25' Tradewind (with two ... three... FOUR dogs)
2011 Ram 1500 Quad cab, 5.7 Hemi, tow pkg.
kevin242 is offline   Reply With Quote
Old 05-15-2011, 07:53 AM   #4
Michigander's Avatar
2005 30' Land Yacht 30 SL
Oakland County , Michigan
Worth a try?
Sounds like a great idea! I would use the shop vac, though, to avoid gas/oil exhaust fumes from entering and staying in the TT.
Also, Steve, running lights really take a beating from the sun, etc. I re-sealed mine on the front of my MH and cured my problem. Good luck.
Bob & Nancy
2005 ASLYG 30 SO
2009 Wrangler Toad
Michigan
Michigander is offline   Reply With Quote
Old 05-15-2011, 08:01 AM   #5
Maniacal Engineer
barts's Avatar
Menlo Park , California
I found that the seam between the body and the tail lights appeared to leak water on our 71 Tradwind... I sealed all around the top and sides with Gutterseal and the problem went away. I didn't remove all the interior panels to verify that this was the source of the leak, but it seems at least plausible.
One trick you can do if you have enough dry weather is to make it "rain" locally: wet the area you suspect of leaking with a hose.
Where does the air conditioner drain hose run?
- Bart
Bart Smaalders
Menlo Park, CA
http://tinpickle.blogspot.com
http://smaalders.net/barts
barts is offline   Reply With Quote
Old 05-15-2011, 08:13 AM   #6
Sewer vent pipe cover gaskets last 2 to 3 years.
Your description of the location, says thats where the leak is at.
Old 05-15-2011, 10:43 AM   #7
McDonalds's Avatar
Bowdoinham , Maine
Hey thanks for the input, but I don't get how the sewer vent pipe could be the cause. The vent is well north of the actual leak. I've laid towels back there and there is no overhead wetness on the towels. I get that the water could travel down the pipe and then leak. But the rotten plywood is just inside the trunk, right next to the back wall behind the tub. Also, if I get this stopped, is there any cause for other concerns? The whole area rotted is only about 4"x5".
Old 05-15-2011, 11:30 AM   #8
The water follows the vent pipe from the roof down.
Thousands of owners have experienced your current issue.
Please take the cover off and "look".
Old 05-15-2011, 02:28 PM   #9
Florissant , USA
Worth a try?
This is not a good way to accomplish this. Even running a shop vac or leaf blower at max capacity long term, it will not properly pressurize the interior. The machine designed for this testing is called a Sealtech 430R. It has a large squirrel cage impeller that can be adjusted to pressurize small to larger trailers. This is the machine I use, and it works very well.
Steve
Old 05-15-2011, 04:39 PM   #10
Colin H's Avatar
1957 30' Sovereign of the Road
1959 28' Ambassador
1949 24' Limited
Peru , New York
Steve
Yeah, Steve is right. I have a 430R too & it works well. I'll second the earlier comments about the marker lights & vent gasket. Take each one of those off & re seal, then take it to a professional. There should be an RV shop in your area that has a 430R.
Leaks are always a chore but they all have them.
Good luck,
Colin
Colin H is offline   Reply With Quote
'83 sofa back piece folds out yonallycamp Upholstery, Blinds, Walls & Interior Finishes 1 04-30-2011 02:59 PM
Should I add wheels to the back bumper? Scott J-24 Towing, Tow Vehicles & Hitches 12 04-04-2011 06:40 PM
Placement of lower curtain tracks over back gaucho 73 Tradewind. constructor Upholstery, Blinds, Walls & Interior Finishes 1 03-17-2011 06:22 AM
Need back hatch for my 1964 Safari Safari Bob Exterior Storage Compartments & Access Doors 5 03-08-2011 07:52 AM
How do you cover the back of your truck? aname4me Tow Vehicles 34 03-01-2011 12:36 AM
