Old 06-07-2011, 01:33 AM   #1
1968 20' Globetrotter
1957 22' Flying Cloud
Tracy , California
Help, leak in my '68
Help, I had my 68 globetrotter for about a year and starting to restore the inside. Well, I just noticed I have a good size leak comming from the street side wheel well. The water is comming from under the plastic cover under the well and draining onto the flooring. Is it possible the leak could be comming from the roof and draining down the interior sides of the trailer. Are the airstreams designed that way? Could somebody give me some suggestions on what to look for. I don't have the time and money to start taking apart the walls. Thanks for the help
Rickman4 is offline   Reply With Quote
Old 06-07-2011, 05:40 AM   #2
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
Most likely coming from a vent stack opening in the roof for the sink. Check it very carefully. I chased water leaks for 2 years and many times the source was not obvious and not even close to where the leak presented. Might also check the AC. I had a leak on the curb side from that source. If you have an Armstrong, pay special attention to where the refridgerant lines and power cables come thru the top of the trailer. On mine, I caulked it several times with no luck. Only after I completely removed all the old sealer and cleaned the surface around the hole with lacquer thinner and sealed with vulkem did I get the leak stopped.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
Old 06-07-2011, 05:53 AM   #3
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Bruce is on it...start on the roof. On our 63 Safari a vent leak on street side mid showed itself, street side front.
On the Classic a leak in the bathroom, showed dripping from the rear of the street outside wheel well..no telling where it shows it's ugly self.
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
Old 06-08-2011, 12:42 AM   #4
Tracy , California
Thanks for the help. I will be working on it this weekend.
Advice needed on water leak and sub floor damage on 08 Int'l Westfalia Repairing/Replacing Floor &/or Frame 9 03-20-2012 05:25 PM
Water Leak bumper Airstream danyfr67 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 15 06-07-2011 07:43 PM
Rear window leak fixed! Really? I think so. 1964 GlobeTrottin 1960 - 1964 Globetrotter 0 04-30-2011 05:42 AM
Fuel tank leak 1985 345 classic st.stephan Classic Motorhomes 3 04-03-2011 10:08 PM
Battery Compartment Leak Ag'71 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 1 03-22-2011 08:04 AM
