Old 04-16-2005, 02:37 PM   #1
Help I am taking in water
I appreciate all the advice, and help. This is my first trailer, so I will probably ask many questions that have already be discussed.
I noticed on my new 2004 16ft ccd bambi that when ever it get wet, all the outside lights get mosture inside, then many times short out, (no lights)!
I take them off and wipe the mosture but it all happens again. I noticed that there is a rubber seal on the inside, but its not stopping the mosture from getting in. It might be doing it by seeping in around the screw. I noticed that the screw does not have a rubber washer, or any other devise to keep this from happening.
I would think that by now Airstream would have that problem worked out???
Any body elese solved the problem other then using maybe clear caulking all around it, and a dab in the screw slot?
And if thats the only cure, I woulder why they don't do it at the factory??
imagine is offline   Reply With Quote
Water problems Dbraw Fresh Water Systems 14 10-03-2009 02:15 AM
Water Heater Craig 1978- 1979 Excella 500 7 10-01-2007 05:16 PM
travelling w/out water system maznblu Fresh Water Systems 6 09-09-2002 12:03 PM
Low water pressure in Excella murf Fresh Water Systems 7 09-04-2002 07:12 AM
Looking for ideas hot water FrankR Water Heaters, Filters & Pumps 3 05-09-2002 10:28 AM
