Old 02-27-2013, 08:34 PM   #1
1969 18' Caravel
Augusta , Georgia
Help a girl caulk a fridge vent
So the problem is our 9 caravel and her leaky fridge vent. I climbed up there this evening and I caulked around the vent but I think the leak is coming from the parts inside the vent. I couldn't really reach inside with the caulk gun, but I can try tomorrow with another tactic...advice would be great!
Caroline
1969 Caravel "Sylvie"
moderninthesouth.blogspot.com
Modern South is offline   Reply With Quote
Old 02-27-2013, 08:44 PM   #2
eljay's Avatar
1968 24' Tradewind
Rural, blink and you'll miss it , Missouri
Hi! What are using using to seal the fridge vent? Did you clear all of the old sealing material off?
Not knowing enough to be afraid... (I know more than I did, but I did it anyway!)
Eljay
1968 Tradewind Double.
eljay is offline   Reply With Quote
Old 02-27-2013, 08:50 PM   #3
altnbndr's Avatar
1967 17' Caravel
1968 22' Safari
Sacramento , California
Images: 11
caulking hard to reach areas
I do architectural sheet metal and what I do at work when I have a hard to reach place to caulk that a caulking gun won't fit into is:
1. put a blob on my finger and smear it in.
2. put a piece of vinyl tubing as a extension nozzle on the end of the tube or 3. use a syringe if I need a fine line
Hope this helps.
altnbndr is offline   Reply With Quote
Old 02-28-2013, 04:30 AM   #4
1969 18' Caravel
Augusta , Georgia
Caulking the vent
It did not have caulk there before. I did try putting some on my finger and reaching over vent and down but that didn't go so well. I am going to try the syringe trick today. Thanks for both of your advice!
Caroline
Old 02-28-2013, 06:02 AM   #5
eljay's Avatar
1968 24' Tradewind
Please be sure to use Vulkem/Trempro 625 or 626.
Eljay
