Old 04-20-2007, 08:21 AM   #1
crispyboy's Avatar
1994 30' Excella
alexandria , Kentucky
Glass to window frame sealant
I searched the forums on sealing but I still have a quick question on sealing.
I need to replace the cauld that is up against the glass and the window frame on my 1981 trailer.
Question 1: Is this a job for VulKcem and a syringe or the Parrbond sealant?
Question 2: For sealing around the window frame I plan to use the Vulkem. Is this correct?
thanks,
Steve
crispyboy is offline   Reply With Quote
Old 04-21-2007, 07:12 AM   #2
Devils Lake , North Dakota
" Question 2: For sealing around the window frame I plan to use the Vulkem. Is this correct?"
I just ordered 4 tubes of Acryl-R which from what I understand is the way to go to seal the window frame
to exterior skin seam.
Window to frame I am unsure of.......
Sundance is offline   Reply With Quote
Old 04-21-2007, 08:11 AM   #3
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
What I did for glass to window frame was use a razor knife to cut the old ragged gray seal back, then taped the glass and frame and used Vulkem. You can use Vulkem or Sikaflex interchangeably. My understanding is that Acryl-R is for smaller cracks. However I bought a new Vista View from Airstream that leaked between the glass and the frame and they suggested using the Acryl-R to seal it up. (QC is still an issue... ) Someone here has taken a window apart and rebuilt it using a black seal to replace the gray stuff, this is an involved process and not for the faint of heart!
Aaron
WBCCI #XXXX AIR #2495
Old 04-21-2007, 10:33 AM   #4
Excella CM's Avatar
1978 31' Excella 500
Venice , California
Another vulkem like product (polyurethane) is 3M marine adhesive sealant. It comes in caulking gun tubes and comes in three colors: white, black, and tan. Product # is 5100. It's expensive (@$15 a tube). It takes several days to set up but makes an impressive bond. Its surface finish is like the silicone sealants (shiny) but it is much stronger. A fast setting variety is also available. Well worth the investment to play with a tube. Like vulkem, cleanup is with mineral spirits.
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Curved side window replacement michel88 Windows & Screens 7 09-29-2006 09:20 AM
side front window for '74 Argosy dootsie Windows & Screens 2 10-23-2002 08:28 AM
Acrylite Window Replacement Gordon Watt Windows & Screens 12 08-12-2002 08:46 AM
Front Wing Window Repair Charles D. Bennett Windows & Screens 0 08-10-2002 06:04 PM
Window Frame Removal 64GT Windows & Screens 4 04-09-2002 12:40 PM
