Old 04-06-2016, 10:16 AM   #1
1972 27' Overlander
Lamar , Missouri
gasket material-?
I am re-caulking all exterior seams with Tempro on the new 72 International. On the plumbing vents, the exterior light housings, the 7-way plug housing there seems to have been gaskets.
I was thinking of making cork caskets (material from auto supply) then sealing with a bead of tempro.
Is there something better than cork or should I just make good bead of Tempro and attached the items back?
Some of the original sealant I am digging out is still pliable!
walleye001 is offline   Reply With Quote
Old 04-06-2016, 10:47 AM   #2
dennis3751's Avatar
1976 29' Ambassador
Fitchburg , Wisconsin
I think the plumbing vents should have a rubber like material not cork. The pipe may move around some and break the cork pretty quickly. You can get vent pipe gaskets from many vendors including Out of Doors Mart and Airstream dealers. Fairly inexpensive and fit well. Cork should be fine for the lights but I'd go for "rubber" material at all 3 points.
Dennis
dennis3751 is offline   Reply With Quote
Old 04-12-2016, 10:17 PM   #3
Send beer
Cheetahfoot's Avatar
1977 27' Overlander
Bainbridge Island , Washington
Uv
I would thing a EPDM, butyl, or some sort of more weather resistant material would be a better choice than cork a good flexible sealant should also work. Of course that's how I ended up here, looking to see what everyone uses for a sealant. I have sealed a lot of metal roofs and siding on houses but want to see if there is anything here that people favor aside from the Vulkem
Cheetahfoot is offline   Reply With Quote
Exterior gasket material? NicheVintage Leaks - Weatherstrips, Gaskets, Caulks & Sealants 6 01-31-2011 08:56 PM
Gasket Material for rib before installing Interior skin CapnTom Ribs, Skins & Rivets 13 01-19-2010 07:56 AM
Counter Top Gasket Material Tom Bray Cabinets, Counter Tops & Furnishings 9 04-25-2008 11:21 AM
Gasket Material for Kitchen Fan Cover bevman Roof Vents, Skylights & Fans 1 06-28-2007 07:39 PM
1968 Door gasket material Boondocker Doors & Locks 1 05-15-2007 07:34 AM
