05-02-2011, 08:52 AM
Head out
2007 25' Classic
Villa Ridge
, Missouri
Gasket lubricant
What is the best lubricant product to apply to the front window gaskets?
05-02-2011, 08:59 AM
2009 27' FB International
Los Angeles
Went to Camping World and they recommend a pure silicon spray to apply via a paper towel or rag. Looking forward to hearing what the pros recommend.
Scott, Becky & Heidi (our standard poodle and travel companion)
WBCCI #1215
Air #54601
Remember... No matter where you go, there you are...
2009 27FB International Ocean Breeze
2010 Toyota Tundra CrewMax, 5.7L V8, 4x4
05-02-2011, 09:00 AM
St. Cloud
I'd trust Lewster ... http://www.airforums.com/forums/f454...tml#post439162
You'll find fantastic fan covers will stick after a while too. That's a little more precarious to approach. Don't dimple the end cap!
What is your 'Stream year & model?
05-02-2011, 09:01 AM
St. Cloud
And welcome to the forum by the way!
05-02-2011, 09:26 AM
2005 30' Classic
Burlington
, Ontario
I use this product.
303 Products, Inc.: 303 Aerospace Protectant
You can often find it at places that sell marine supplies.
If, after long storage, I have a window sticking to its gasket despite use of this product, I
pull the widow open with a suction cup. The type that has a vacuum release. I think it is safer than trying to pry the glass open - although I initially did that using popsicle sticks! I'm afraid prying might break the window, although I'm sure it is tempered glass.
I have Fantastic fans with power openers. Quite often the first time I want to use them, they stick and cannot be opened by the motor. In that case I just help the motor along a bit by applying a light pressure to the manual opener knob at the same time the motor is turning it.
Occasionally it still doesn't want to open, so then I reverse the motor to close the lid down tight, t hen try to open again - so far, that has always worked on one try!
Brian,
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
05-02-2011, 10:23 AM
Corona
lube
All the exterior gaskets should be lubed with "silicone spray". Apply a genereous amout, leave it in place for a couple od days, and then wipe the gaskets with a cotton rag. Repeat every year or so.
The reefer door daskets should also be lubed the same way.
A small amount can also be sprayed on the ceiling vent gaskets.
05-02-2011, 10:36 AM
2010 27' FB Classic
N/A
X2 on the 303. It works great!
"There’s two kinds of people, them goin’ somewhere and them goin’ nowhere. And’s that what’s true". -Ben Rumson
05-02-2011, 11:02 AM
Liberator
1972 Argosy 24
1989 34.5' Airstream 345
Heart of Dixie
, Alabama
Are you installing the windows ?
If you need lubricant to help it slide as you install, soap works best on anything rubber.
Your opinion is valued, please not your opinion of someones else's opinion.
Click To See Me Wet
1989 Airstream 345 Liberator...
1972 Argosy 24'...
1954 Feathercraft Vagabond
05-02-2011, 11:07 AM
Oswego
X3 on the 303! Use it on LOTs of stuff. Love it.
