Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Leaks - Weatherstrips, Gaskets, Caulks & Sealants
Old 07-27-2009, 10:06 AM   #1
Profile:  1978 31' Sovereign
Cincinnati , Ohio
Front / rear window removal on a 78'
I am currently in the process of replacing all the window gasket material on my 78' Soviergn. I am done with the (6) side window and it was no problem. I have zip dee awnings installed on the front and rear of the Airstream and if the windows at the front and back are similar (i suspect they are), my question is: Do I need to remove the awnings to remove the window. I ran out of time this weekend, but I thought I would see if anybody else has encountered this problem. It looks like the the window will hit the zip dee and not allow me to raise it enough to get the window to drop out of its track.
Eric
http://e-rock53.blogspot.com/
erock53 is offline   Reply With Quote
Old 07-27-2009, 10:59 AM   #2
Commercial Vendor
Profile:  Corona , California
Eric
It depends on exactly where the awning was mounted, vertically, as to the window hitting it or not.
The small windows awnings are easily removed, if they are in the way.
For exact instructions, call Zip Dee at 800-238BEST.
Andy Rogozinski
Inland RV Center
Corona, CA
Front Television Removal ppillard Land Yacht/Legacy Motorhomes 48 08-19-2009 03:55 PM
Window leaks--front and rear? Kistler Windows & Screens 8 08-02-2009 03:10 PM
Globetrotter '76 front window removal & more kentuvman Exterior Restoration Forum 5 09-28-2008 07:31 AM
1985 25ft. Front/rear wraparound window model mcrickc 1984 -1986 Excella 1 09-29-2007 09:34 PM
64 Safari front & rear window achip Windows & Screens 2 09-06-2006 10:43 AM
